Gamma MCA is a complete progressive web app for gamma spectroscopy. It is free and open-source with online and offline functionality. You can import and export spectrum files or record new ones using the serial interface.
I've built this thing originally to have something to connect my Open Gamma Detector and read the data live from it. Because, as far as I know, all the programs out there only work with audio data and soundcards, it was my job to create something new.
You can have a look at the Gamma MCA application in your browser, right now: https://spectrum.nuclearphoenix.xyz/
If you're running a Chromium-based web browser (Google Chrome, Opera, Edge, ...), you can also install it to your machine like any other native app. It will also work offline!
The source code can be found on GitHub: https://github.com/OpenGammaProject/Gamma-MCA
