SubPos Positioning System
oshparkoshpark wrote 06/03/2016 at 18:38 • 3 min read • Like
492341434335853387
Blecky developed a Wi-Fi positioning system to be used where GPS won’t reach:
SubPos is an indoor positioning system that can be used in various environments such as metro lines, shopping malls, carparks, art galleries or even conference centers; essentially anywhere GPS doesn’t penetrate. It could also be integrated into an array of IoT enabled devices, from access points to Wi-Fi enabled light-bulbs.
5495321436789611001
SubPos Nodes transmit encoded information in a standard Wi-Fi beacon frame which is then used for position trilateration:
The Nodes provide a pre-calibrated device that is easy to configure and can be dotted about with ease:
The hardware files and firmware is available on GitHub:
SubPos Node Gerber Files and Firmware
blecky has shared the board on OSH Park:
SubPos
Order from OSH Park
SubPos Receiver
The source code for a receiver module which works with the ESP module:
2651671454235412405
Tested on Arduino and the Teensy 3.2 as well as Energia and the Launchpad Tiva
SubPos Ranger
Blecky is now working on an extended ranging system based on 802.15.4 for use with the SubPos Positioning System:
Source: https://hackaday.io/project/9242-subpos-ranger
Like
