How to connect my Cricut Maker 3 to Bluetooth is the most frequently asked question I receive from my readers. The question is easy to answer, and I will make it easier for you.
I remember the day I got my first Cricut Maker 3 machine. I was a little bit, but somehow, I learned to connect Cricut to a device using Bluetooth. When I can do this, you can also do it in no time. For this, you will need a compatible computer or mobile device to which you want to connect. Let’s learn how to connect a Cricut machine with different devices, including Windows, macOS, iOS, and Android. Let’s delve into this blog and start establishing a connection.
How to Connect My Cricut Maker 3 to Bluetooth on Windows?
Connecting your Cricut cutting machine to a Windows computer using Bluetooth is not rocket science. By following the simple steps given below, anyone can easily connect their Cricut to their PC.
Here’s how to connect Cricut Maker 3 to Bluetooth on Windows 10:
- Before connecting, find a flat surface on which you can place your Cricut product.
- After that, confirm whether the distance between your PC and Cricut is within 10 - 15 feet (Make sure it doesn’t exceed 10 feet).
- Now, you should go to your Windows desktop and click on the Start menu located in the taskbar below.
- Next, you will see a small circular gear icon, which is your Settings. Click on it to open Settings.
![](https://cricutdesignappspace.wordpress.com/wp-content/uploads/2024/05/how-to-connect-my-cricut-maker-3-to-bluetooth-1.png?w=491)
- As you enter your PC’s Settings, you will see the Devices option. Click on it.
![](https://cricutdesignappspace.wordpress.com/wp-content/uploads/2024/05/how-to-connect-my-cricut-maker-3-to-bluetooth1-1.jpg?w=1024)
- Then, look for the Bluetooth option.
- In the following step, check if your Bluetooth is ON.
- If it is turned on, click on Add Bluetooth or other device.
![](https://cricutdesignappspace.wordpress.com/wp-content/uploads/2024/05/how-to-connect-my-cricut-maker-3-to-bluetooth3.jpg?w=787)
- Afterward, you must select the Bluetooth option.
- Wait a while for your PC until it finds your Cricut machine.
- Once it is visible on your list, select the model to pair, and that’s it.
How to Connect My Cricut Maker 3 to Bluetooth on Mac?
Cricut is easily compatible with the MacBook. Besides, the first and second steps are the same for all devices as for the Windows computer. So, take out your Cricut machine outside or unbox it if you haven’t done it yet and start connecting it to your Mac.
- Again, the first and second options will be the same as for the PC (See the above step for the PC).
- Now, you have enabled Bluetooth. To do this, proceed to the Apple menu.
- Then, select the System Preferences option.
![](https://cricutdesignappspace.wordpress.com/wp-content/uploads/2024/05/how-to-connect-my-cricut-maker-3-to-bluetooth4.png?w=296)
- Here, you need to search for the Bluetooth option.
![](https://cricutdesignappspace.wordpress.com/wp-content/uploads/2024/05/how-to-connect-my-cricut-maker-3-to-bluetooth5.jpg?w=780)
- When the Bluetooth is ON, you have to select your Cricut machine from the available list.
- Lastly, when your Cricut is connected to your Mac computer, your pair is done.
How to Connect My Cricut Maker 3 to Bluetooth on iOS?
So, now I am going to talk about the steps to connect your Cricut cutting machine to your iOS devices, including your iPhone or iPad. The steps will be the same for both iPhone and iPad devices.
Here’s how to connect your Cricut machine to your iOS device via Bluetooth:
- Being an Android user, you should navigate to your Settings.
![](https://cricutdesignappspace.wordpress.com/wp-content/uploads/2024/05/how-to-connect-my-cricut-maker-3-to-bluetooth6.jpg?w=624)
- Once you reach your Settings, go to the Bluetooth option.
- Now, enable your Bluetooth.
- Once done, wait until your iPhone or iPad finds your nearby Cricut machine.
- When you can see the Cricut model, select it to pair.
How to Connect My Cricut Maker 3 to Bluetooth on Android?
Android users can also establish a connection between their Cricut Maker 3 and Android smartphones without any hassle. All you need is an Android phone that is compatible with Cricut.
- Turn on the Cricut machine and ensure your devices are placed within 10-15 feet.
- After that, you need to launch Settings.
- Now, you need to go to Bluetooth and turn it on.
- Then, you need to pair your Cricut product.
- As you start pairing, it will search for your device.
- You have to select your Cricut model when it appears in the list.
- In the following step, click the pair if prompted.
- Finally, your connection is done.
FAQs
Question 1: What if I can’t connect my Cricut machine to Bluetooth?
Answer: Here are some things that you must try to connect:
- Make sure you have turned on your Cricut machine
- Then, confirm that your Cricut machine is within 10–15 feet of your computer
- Try unpairing your Cricut from your device’s Bluetooth settings
- You can also update your Bluetooth driver
Question 2: What’s wrong with my Cricut that it doesn’t connect?
Answer: It is probably some of the reasons that you must know. First thing, you will need to know whether you have connected your Cricut to your computer or mobile device. It should also be connected to the WiFi network. If everything is okay, you can check your other cable connection.
Question 3: Which MacBook should I try with my Cricut?
Answer: I think the Apple MacBook Air (M2, 2022) is the best, in my opinion, as it is comfortable and portable in performance. Windows computers properly need to connect with each other. For this, users can check their system requirements and choose Mac accordingly. Besides, I prefer to have this MacBook Air laptop.
Visit: install cricut design space app www.cricut.com setup login cricut.com/setup
