Cricut Explore Air 2 is a magnificent machine if you are looking to get into the world of crafting. It is a budget-friendly Cricut machine that you can use to cut different types of materials and work on various DIY projects. To install Cricut Explore Air 2, you will need to follow a few simple steps. In this blog, I am going to write about them, and after reading them, you will be ready to go.
![](https://cricricutdesigncut.wordpress.com/wp-content/uploads/2024/05/how-to-install-cricut-explore-air-2-1.jpg?w=1000)
In this guide, I will introduce you to the Explore Air 2 machine, explain the installation process, how to download Cricut Design Space, and so much more. Without any further delay, let’s get started.
Introduction to Cricut Explore Air 2
Cricut Explore Air 2 is an amazing cutting machine and the best addition to the Cricut family. The machine gives you a great opportunity to cut and craft your materials. With the help of the Explore Air 2 machine, you can cut more than 100+ materials, such as cardboard, leather, paper, cardstock, vinyl, fabric, and more. You can rely on this Cricut machine for your daily crafting.
![](https://cricricutdesigncut.wordpress.com/wp-content/uploads/2024/05/install-cricut-explore-air-2.jpg?w=892)
It comes with an automatic function that allows you to cut a range of materials. This machine can do complex projects in a very simple way, so it’s a great choice for your DIY projects. Let’s move on to the installation procedure in the section below.
Install Cricut Explore Air 2: Quick and Easy Steps
To install the Cricut cutting machine, the first thing you have to do is unbox it and set everything up, like the power supply and internet connectivity. I will tell you all the basic steps you need to follow.
- To get started, you have to unbox the Cricut product and remove the protective covers.
- Next, check for the items in the box and make sure no item is missing.
- After that, plug in the Cricut machine and power it on.
- Then, connect your machine to your computer or phone using a USB cable or Bluetooth.
- Go to cricut.com/setup on your device and download the Cricut Design Space app.
- Open the Design Space app and sign in with a Cricut ID and password.
![](https://cricricutdesigncut.wordpress.com/wp-content/uploads/2024/05/how-to-install-cricut-explore-air-2.png?w=512)
- If you are a first-time Cricut user, create a Cricut account.
Download Cricut Design Space on Your Operating System
Cricut Design Space is the software that you can use to choose designs, fonts, and projects for your crafting. Downloading the app is crucial to install Cricut Explore Air 2 on your device. To download the software, follow these steps:
- Initially, go to an internet browser and open cricut.com/setup.
- Then, press Download to start downloading the Design Space app.
![](https://cricricutdesigncut.wordpress.com/wp-content/uploads/2024/05/install-cricut-explore-air-2-setup.png?w=844)
- After that, you will see that the file is saved in the Downloads folder.
![](https://cricricutdesigncut.wordpress.com/wp-content/uploads/2024/05/how-to-install-cricut-explore-air-2.jpg?w=790)
- Next, go to the Downloads folder and double-click the file to open it.
- Now, agree to the Terms and Conditions, and the installation process will start.
- When the installation is complete, sign in to your Cricut account.
Create a New Cricut Design Space Account
When downloading the Cricut app is done, then log into your Cricut ID. In case you are new to Cricut and do not have an account, you can create one. Simply follow these steps:
- Go to your mobile or computer and open a browser.
- After that, you should go to the cricut.com/setup website.
- Now, insert the Cricut ID and password to log in.
- If you are new to Cricut, create an account using the steps below.
- Next, click on the Sign Up to create a new account.
- Then, you will have to insert your name, email, and country.
- Also, input the strong password and remember it.
- Agree to the terms & conditions and follow the directions to proceed.
- Lastly, complete the sign-in with the newly made Cricut account.
Conclusion
In short, you read everything you need to know to install Cricut Explore Air 2. It is a great machine if you want to explore the world of crafting. This was an important procedure for you if you want to install the Cricut cutting machine. In this blog, you learn how to unbox the machine after buying it and then set it up. Once the Cricut machine is set up, you have to download the Cricut Design Space app and log in with the Cricut ID and password. Once the process is complete, you are ready to begin your crafting journey.
FAQs
How Do I Install Cricut Design Space on My PC?
To install the Design Space app on your computer, you should first connect your device to a stable WiFi network. After that, open your computer’s browser, then go to cricut.com/setup, and click on Download to start the app downloading. Now, go to the Downloads folder and start the app installation process. Once the app is installed, open it and log in with the Cricut username and password.
What Are the System Requirements to Install Cricut Explore Air 2?
To install the Cricut machine, you need to download the Design Space app. To run the software on your computer, you should have at least 4GB RAM and 2GB free disk space. The computer must have a USB port or Bluetooth connectivity option. If you are using a Windows computer, then it should be Windows 10 or the latest operating system. The screen resolution of the computer’s display should at least be 1024x768 pixels.
How Do I Pair My Cricut Explore Air 2 to My Computer?
You can pair your Explore Air 2 machine using a USB cable or via Bluetooth. To connect with a USB cable, you have to connect one side of the cable to the machine and the other side to your computer. To connect through wireless Bluetooth, go to the Start menu on your computer and open Bluetooth settings. After that, search for your device. When you see the name of your machine, then select it, and you will see that your Cricut machine is connected.
