Peachy Printer Laser Diode
Tom wrote 07/11/2016 at 12:51 • 0 pointsDoes anyone know what the laser diode used in the Peachy Printer is?
From the assembly videos, it looks like they're just using a laser diode module, but with no external optics (other than the mirrors on the galvo) it can't be just the diode. A cheap, high(ish) powered 405nm laser with built-in optics would be a useful thing to know about, but I can't see any reference to a part number - it doesn't show up in the Eagle BOM, I guess because it's fitted into a socket on the board and doesn't appear on the schematic.
Any ideas?
AFAIK the only external optics built by the Peachy Printer crew are the windows. On the house they built.
LOL! It took me a while to decipher that.
I should not laugh. Maybe you were a backer. I probably would have been a backer if I had had the cash.
I know. But, watching the assembly video, they've actually figured out nice, elegant solutions to a lot of problems in DIY stereolithographic printers. Some highlights:
* Their build platform is so, so clever. A plastic bottle and some plastic tube make a reservoir which drops salt water into the build vat. A sensor, which you can build from a piece of plastic, some aluminium wire and some heatshrink, counts the number of drops. The resin floats on the salt water, so if you know approx the volume of a drop and the size of the container, you can figure out how far from the bottom the current build layer is. As simple as that; a build platform with *no moving parts* that you can build from scrap.
* They build a fairly effective galvanometer from a few off-the-shelf magnets, some laser-cut plastic, a couple of off-the-shelf coils and some elastic string. It's open-loop control, so the precision isn't great, but then you could easily imagine making one of these with no tools beyond a sharp knife and a soldering iron. This looks like a fairly fruitful area for improvement of the design; add fast feedback control of the galvo and you'd improve the print quality substantially. Personally, I'm looking at using hard drive voice coils and a capacitative position sensor (ever notice that the arm on a hard drive head looks a lot like half of a variable capacitor?)
I don't know what exactly they're using, but bare 5.6mm diodes and housings are available cheap on ebay. Add your favorite driver, and you're all set:
http://www.ebay.com/itm/405nm-150mW-Blu-ray-burning-UV-Ultraviolet-laser-diode-US-Seller-FAST-SHIP-/182047160979
http://www.ebay.com/itm/Aixiz-laser-module-5-6mm-TO-18-diode-housing-US-SELLER-FAST-SHIP-/182191743508
some of the housings say they're specifically for 405nm diodes - I'm not sure if the optics are any different on those or not.
Thanks for the tip.
