With a vision to make pro mugs at home, all the DIYers are introduced to how to set up Cricut Mug Press. Through this masterpiece, one can make custom-designed sublimation mugs with compatible Ceramic Mugs & Infusible Ink. Moreover, one needs to design, attach & insert the mug blank, and the press will do the rest of the work. The crafter can simply draw their design from the Design Space app/software.
Other than that, the Infusible Ink system gives smooth, pro-quality transfers, becoming one with a mug and making it long-lasting. This Cricut press allows the user to discover their creative side by creating various mugs for different occasions. Besides, the crafter needs to buy a Mug Press along with the bundle and other supplies to create the custom mug.
Let us help you out by showing in-depth Cricut setup Mug Press primary details in the coming section.
How to Set Up Cricut Mug Press on a Device?
Before getting the personal mug, all the users need to set up/activate their Mug Press. To complete the machine activation process, read the steps given below:
- First, go to the Cricut setup official page and download Design Space on your system.
- Following this, create your Cricut ID or sign in with your Cricut ID and Password.
- After getting connected to the Cricut Setup page, choose Heat Press > Mug Press.
- Next, plug into the Mug Press and Power on the wall outlet switch.
- Following this, take the provided USB code and put it inside your device and the machine port.
- After doing these steps, tick the Activate option and start reading the Terms & Conditions.
- Lastly, choose Get Started and start creating your first project on Mug Press.
After finishing up the Cricut setup Mug Press process, take a step forward by knowing how to use it for crafting purposes.
How to Use Cricut Mug Press?
After setting up the Cricut Mug Press, the user can easily create custom mugs in minutes with simple and one-touch settings. Get to know about the steps given below:
- Start the process by creating your design on the Cricut app by using a mug template or any pre-made mug design.
- Next, spread the Infusible Ink sheet on the purchased cutting mat with color side up & shiny side down.
- Following this, cover up the mug with the design using the transfer sheet to avoid any bubbles.
- Now, preheat the machine by turning it on and pressing the Power button.
- After the heating process is complete, it will start beeping, and the Power button will turn green.
- Next, place the mug inside into the press and close the lid available on the right-hand side.
- Now, you are suggested to wait till the heating process is going down.
- After the mug cools down, remove the sheet without damaging the design.
- Here you go; making a custom mug with this press is so much fun.
How to Change Cricut Mug Press Temperature Settings?
For top-quality custom mug results, all the users should be aware of the process by which they can modify the machine temperature settings. Get to know about the steps below:
- First, enter the Temperature Setting mode, whether the press is switched on or off.
- Next, select and hold the power button for 10 seconds.
- After that, you will hear two chimes, and all the LEDs will start flashing at once.
- Now, you will get to see that the power button will be flashing orange during the Temperature Setting mode.
- Afterward, the LED row will start displaying the present setting. You have to push the Power button to cycle through the 3 settings options:
- Following this, hold on the Power button for 3 seconds to select the settings after getting the desired LED setting on the display.
- After that, a chime will be heard with an LED display, and a Power button will be flashed.
- Next, your Mug Press will turn off, exiting the Temperature Setting mode.
- Lastly, the new settings will come into action when the press is switched on.
Summing up the above-said section of the blog, we hope that you have understood how to set up Cricut Mug Press with Windows/Mac systems.
Frequently Asked Questions
How Can I Update the Cricut Mug Press Firmware?
The firmware ensures that the machine has the latest and greatest feature enhancements. However, to get those updates, they need to follow the steps given below:
- Begin the process by putting the machine into connection mode and opening the app.
- After signing in to the app, go to Mug Press and follow the on-screen steps.
- Wait till the software scans the available firmware and will automatically begin it.
- Once the update comes to an end, disconnect the USB coder from the press.
How Much Time Does It Take to Completely Heat up the Mug?
The Cricut Mug Press takes almost five minutes to completely get heated up. After inserting the mug blank inside the space, the user is supposed to wait six minutes during the process. The press will send a *ding" sound indicating that the press has completed its work. Take the mug out of the place and let it rest for at least 30 minutes before removing the transfer sheet.
How Can I Prepare the Mug Blank for Pressing?
To get the flawless result, press only the smooth, straight area of the mug. Other than that, it ensures that the design is completely flat against the mug surface. Align the design so it stops before the beveled or chiseled edge begins to ignore blurred transfer results. Other than that, flip over the mug upside-down and use the straight edge of the trip rum as a reference to get it on the right spot.
Source: How to set up cricut mug press
For more information visit: Cricut.com/setup
