Changes to Hackaday.io
Patrick Van Oosterwijck wrote 08/29/2016 at 22:30 • 0 pointsI'm not sure if there is a place for this already, but a couple of things that I think should really be changed on Hackaday.io:
- Let people select BOTH hardware and software when they create a project. It's silly on a site where probably >50% of the projects involve both.
- It seems I can paste a picture into the editor when I'm writing a project log. But the picture won't actually show up in the resulting log. Either don't allow pasting and make people use the button to insert a picture (which means you have to first actually make a file out of it, annoying sometimes), or make them show up.
Have you seen the #Feedback - Hackaday.io project?
You can actually add the software tag manually afterwards or edit it. Most of my project are both software and hardware, but I select hardware.
I've seen this trick, too :-)
