Are you finding it a little difficult to understand how to make labels with Cricut? Then, let me show you how I made it possible from scratch in this tutorial. I am the kind of person who loves to be organized, whether it's kitchen items or laundry buckets. Since the holidays are over, I am wrapping up my things and going to high school for studies. Being an organized person, I focus on keeping an eye on my own things, so I decided to make personalized labels.
Being a new DIYer, I was always keen to use the Cricut craft machine, and now I am going to take advantage of this golden chance. It is fine whether you are experienced or not; you should be passionate enough to learn about new things. Let's get started by sharing with you complete details about the process.
Step 1: Create Your Design on the Cricut App
To start from scratch on how to make labels with Cricut, you need to download and install the Design Space app on your device. After that, press the New Project and then tick the Upload option. Now, choose your label design from the gallery and press the Add to Canvas button.
Next, go to the Shapes section and select the square from the list. After choosing the shape, change its size and put your label design inside the square. Following this, tap the Text box and start typing the information inside the box. Then, change the text style, font, size, and color from the Menu section. Following this, fill in the space between the letters by decreasing the number given inside the Letter Spacing drop-box using the arrows.
After completing the text, change the text size as per convenience and place it inside the square. After that, select the whole design and hit the Duplicate button visible under the Layers area. Now, I am going to align all the labels properly by choosing Center Horizontally under the Align box.
Once you are done aligning all the labels, open the Operation box and select the Pen option. Next, choose the pen that you are going to use from the list appearing on your canvas screen.
Further adding to the how to make personalized labels with Cricut process, start selecting the design and tick the Attach option. You will find the option at the bottom right side of your screen. Now, go to the Optimize Experience for section and select your machine from the list. After choosing the model, tap the Make It option present inside the green box.
Step 2: Stick the Mat & Load It Onto Your Cricut Machine
With the finalization of designing labels in this how to make labels with Cricut, you need to answer a couple of questions and tick the Confirm option. Other than that, you can also change your mat size from the Material Size dropbox. Also, tap the Continue option and connect your craft product with your device.
Following this, choose the compatible material and load your Cricut pen into the clamp. After inserting the pen, start loading your Cricut cutting mat into your craft machine. Next, tick the Go button appearing at the bottom right side of your screen.
Next, unbox your cutting mat, use a Cricut trimmer, and cut the extra piece of material. After trimming extra material, please take out the final part of the material and put it on top of your compatible cutting mat. Plus, you can also use the brayer tool for adequately placing the material on the mat without any wrinkles.
After sticking the Cricut material, how to make labels with Cricut, unbox your craft machine, open the clamp, and load a compatible pen inside it. After doing that, insert your cutting mat into the machine and hit the Go button. When the process comes to an end, unload your pen and gently remove the mat.
Step 3: Remove Labels and Apply It
After unloading the cutting mat, remove your labels from the mat and carefully stick them on your jar. While removing the label, you need to ensure that you are weeding out the label with gentle hands and properly sticking it in your jar.
And that's it! Now you are well aware of the complete terms of how to make labels with Cricut. So, pick up your stuff and get ready to make various personalized crafts with this craft plotter.
Frequently Asked Questions
Question: Is It Worth Using Cricut to Make Labels?
Answer: If you are an enthusiastic DIYer and love to make various types of labels for your home, then buying Cricut is the best option. The craft machine is compatible with different materials that can help you make labels for your kitchen or laundry buckets. However, Cricut Joy is one of the models that come with the label-making bundle.
Question: Are Cricut Labels Permanent?
Answer: If you want a label that lasts long, then you should definitely choose Cricut permanent vinyl. This vinyl comes with a strong adhesive that sticks on the surface, is water-resistant and UV-resistant, and lasts up to 3 years. Before applying the labels, you need to ensure that the project surface is clean and dry and stick the vinyl in the correct place.
Question: Which Materials Can the Cricut Joy Cut While Making Labels?
Answer: Cricut Joy is a small, portable, and easy-to-carry craft machine that cuts 50+ materials with its sharp blades. With the help of this craft model, it can precisely cut materials such as:
- Foil Poster Board
- Cardstock
- Faux Leather
- Dry Erase Vinyl
- Paper
- Balsa Wood
