Hey crafters, are you searching for something like Cricut create connect to computer or how to create a Cricut ID? If so, you have come to the right place! Being a Cricut expert, I understand how tedious a Cricut account and machine setup can be. But you don’t need to worry about that, as I am here to teach you how to connect Cricut to Bluetooth and create a Cricut ID.
A few days ago, I received a mail notification from Quora. In it, someone asked a question regarding the Cricut machine setup and creating a new Cricut account. I answered it, but then I had a realization. I thought many Cricut users (especially beginners) might be looking for an answer to this same question.
Therefore, I decided to write a complete tutorial covering everything about the Cricut connection and creating a new Cricut account. To learn more, you need to delve into this blog.
How to Connect Cricut to Bluetooth on a Computer?
Every Cricut user tries to know about Cricut create connect to computer to establish a connection between a computer and Cricut. This is what I call a Cricut machine setup. So, if you are going to set up your Cricut account, you first need to connect your Cricut cutting machine to a computer using a Bluetooth or USB cable.
Below, I will show you the steps for connecting your Cricut to a Windows 11 computer using Bluetooth:
- Before connecting Cricut to Bluetooth, you must ensure your Cricut machine is powered on. Also, ensure the distance between your machine and the computer is not more than 15 feet.
- After that, turn on the Bluetooth on your computer.
- Then, you will have to add your Cricut machine. To add, click on Add Bluetooth or other device.
- Next, you must click on the Bluetooth option and wait a while for your computer to detect your Cricut machine.
- Now, your machine model name will appear in the list. Select it to pair.
- Also, you might be asked to enter four digits of your PIN, which is 0000.
- In the last step, you have to hit the Connect button.
How to Download Cricut Design Space on a Computer?
Have you connected your Cricut to a Bluetooth computer now? If yes, you have to now download Cricut Design Space by following the simple steps below:
- Open a Chrome browser or any other browser that you like.
- Then, on the search bar, you have to search for design.cricut.com.
- Next, mark the checkbox to accept the terms and conditionsand then hit the Download button to begin downloading.
- Now, go to the Downloads folder in your file explorer and double-clickthe .exe file to install the app.
- Afterward, you will need to follow the instructions given on your screen to install the app.
After downloading this Design Space, you will need to create your Cricut account. To create, move to the next section. In it, I have covered everything about Cricut create connect to computer.
How to Create a Cricut Account on a Computer?
Now, you might have installed the Cricut account on your computer. Let’s create an account. Below, I have provided the steps to create an account for your Cricut:
Note: Before you proceed, ensure you have downloaded and installed the Cricut Design Space on your compatible Windows computer.
- Open the browser on your computer and visit cricut.com/setup.
- You will need to click on the green Get Started button at the bottom of the screen.
- You will now move to the new screen, where you have to enter your first and last name, including your email address.
- Then, select your country, such as the United States, Canada, or the United Kingdom, from the drop-down menu.
- Now, read the Cricut terms of use and then hit the checkbox.
- After that, you will have to click on Create User ID.
- Finally, you will see the confirmation message, meaning your account has been created successfully.
- Now. hit the Continue button.
Further, you will be asked to give some extra information to Cricut, as shown in the image below.
Ensure you are selecting the correct answer from the drop-down menu.
Finally, we covered the main topic of Cricut create connect to computer, meaning you will now have a new Cricut account connected to the computer using Bluetooth.
FAQs
Question 1: How can I access my Cricut account on my computer?
Answer: To access a Cricut account, you will need to follow the steps mentioned below:
- First, you need to open a Browser on your computer.
- After that, you will need to visit design.cricut.com.
- On the download page, you will need to follow the screen prompts to download and install the Design Space app.
- Once the app is downloaded, you have to Sign In to your Cricut account under the Account Settings icon.
- Then, type the registered email address and password.
- Finally, hit the Sign In button.
Question 2: How to change my Cricut account password?
Answer: We often want to change our password for some reason. However, you can change or reset your Cricut password as follows:
- Make sure you are signed in to your account on cricut.com.
- Then, go to your Profile icon and select My Account to access your account details.
- After that, tick the Change Password box and enter the password.
- Next, you will need to click Save, and hence you have changed your password.
- Next time, when you sign in to the Design Space, you have to use your new Cricut password.
Question 3: Why can’t I sign in to my Cricut Design Space on a computer?
Answer: If you are having trouble signing in to your Design Space, you will need to reset your Cricut ID password. This will ensure a smooth login to your Cricut account. Sometimes, due to technical glitches, you may experience such sign issues. Hence, you just need to reset the password, and that’s it.
Final Words
Overall, in this blog, we discussed Cricut create connect to computer. Simply put, I have explained how to create a Cricut account and connect your machine to the computer using Bluetooth. Throughout this blog, I have covered important topics, such as creating a new Cricut account and downloading Cricut Design Space. And finally, I have taught you to connect your Cricut machine to a computer using Bluetooth. Follow the methods and start crafting what you like!
