How to Realize Android Vertical Screen Display on the Embedded i.MX8MP Platform of Forlinx
forlinx-embeddedforlinx embedded wrote 01/25/2024 at 07:40 • 1 min read • Like
The default display orientation for the Android interface on the Forlinx Embedded i.MX8MP platform is landscape, but some products may require a portrait display. To address this requirement, Forlinx Embedded provides the following methods for modification:
The Android system controls the screen orientation through the persist.vendor.orientation property, which can have values of 0, 90, 180, or 270.
Configuration path: frameworks/native/services/su**ceflinger/Su**ceFlinger.cpp
Modify in processDisplayHotplugEventsLocked:
Su**ceFlinger::processDisplayHotplugEventsLocked() {
             continue;
+       /* Rotate desktop */
+       char rotationvalue[PROPERTY_VALUE_MAX] = "";;
+       property_get("persist.vendor.orientation", rotationvalue, "-1");
+       int rotation = atoi(rotationvalue);
+       ALOGI("Primary Display Orientation is set to rotation %2d.", rotation);
+       switch (rotation) {
+               case 0:
+                       internalDisplayOrientation = ui::ROTATION_0;
+                       break;
+               case 90:
+                       internalDisplayOrientation = ui::ROTATION_90;
+                       break;
+               case 180:
+                       internalDisplayOrientation = ui::ROTATION_180;
+                       break;
+               case 270:
+                       internalDisplayOrientation = ui::ROTATION_270;
+                       break;
+               default:
+                       break;
+ const DisplayId displayId = info->id;
         const auto it = mPhysicalDisplayTokens.find(displayId);
After modification, you need to add the relevant configuration in the environment variable.
Path: device/nxp/imx8m/evk_8mp/system.prop
persist.sys.timezone=Asia/Shanghai
persist.sys.language=zh
persist.sys.country=CN +persist.vendor.orientation=90
Rotate 90 degrees here to write 90, 180 degrees to write 180, 270 degrees to write 270.
If you encounter a failure to set the value of a property:
Add the followings in device/nxp/imx8m/sepolicy/property_contexts;
+persist.vendor.orientation     u:object_r:debug_prop:s0
vendor.wc_transport.                u:object_r:vendor_wc_prop:s0
persist.vendor.usb.config           u:object_r:vendor_usb_config_prop:s0
Like
