Application Solution of Forklift Driver Face Recognition and Permission Collector Based on FET3568J-C SoM
forlinx-embeddedforlinx embedded wrote 01/31/2024 at 07:36 • 3 min read • Like
Forklift is an indispensable equipment in modern industrial production and logistics transportation, but at the same time, it is also a mechanical equipment with certain risks. If operated improperly or managed poorly, it can easily lead to safety accidents, causing injuries and property losses. Therefore, improving the safety awareness and management level of forklift drivers is of great significance in ensuring the safety and smooth operation of enterprise production and logistics transportation.
In the safety protection and protective devices, it is stated that forklifts must be equipped with a driver authorization information collector. This collector is used to bind the driver's personal identity information with biometric information such as fingerprints, iris, facial features, or magnetic cards. The forklift can only be started after the driver's permission is verified.
The forklift facial recognition driver authorization collector is primarily used for driver permission management. With high-precision cameras and facial recognition algorithms, this system can accurately identify and determine the driver’s identity information. It helps ensure that only authorized individuals can operate the forklift, improving safety and security in the workplace.
Only drivers who have undergone professional training and obtained authorization will have their information entered into the system and be granted permission to operate the forklift. Once the system detects an unauthorized person attempting to operate the forklift, it immediately triggers an alarm and takes measures to prevent the forklift from starting, ensuring the safety of operations.
The forklift facial recognition driver authorization collector has the following notable features:
The overall solution for the forklift driver authorization collector based on FET3568J-C system on module is as follows:
FET3568J-C industrial-grade SoM is provided by Forlinx Embedded, which serves as the core of the forklift driver authorization collector. It features a four-core 64-bit Cortex-A55 architecture with a high frequency of up to 1.8GHz, providing powerful performance support. Additionally, it is equipped with a built-in NPU with 1TOPS computational power, meeting the requirements for lightweight edge AI computing.
The SoM has advantages such as high performance, low power consumption, and low cost.
Forlinx RK3568J industrial-grade SoM provides abundant interface resources, making it easy to connect with external modules.
Like
