I am a Cricut enthusiast, and today, I want to tell you something about using heat transfer vinyl. If you are a Cricut user or a crafter, you may be familiar with the different types of crafting tools. But, if you haven’t tried a heat project yet, I am going to share everything I know with you to help you learn how to use Cricut heat transfer vinyl.
Well, I have been using my Cricut Maker and Cricut Design Space to create designs online and then imprint them on my favorite materials. You can use any Cricut machine, as the steps will be the same for all. But there are some reasons for me to use a Cricut Maker rather than others. I will be creating a yellow T-shirt with my heat transfer vinyl. You can get an idea to make something on your own with your style. Here we go!
Cricut Materials and Tools for Creating a Personalized Shirt
You should know what tools, materials, and equipment are necessary for you to start with your project. Here is the list of them.
- Your brand-new Cricut machine
- Weeding tool
- StandardGrip mat
- Cricut EasyPress 2
- EasyPress mat
- Heat transfer vinyl
- Blank T-shirt/tote bag
With the help of all this equipment, you can get started with your final project.
How to Use Cricut Heat Transfer Vinyl to Make a Shirt?
So, I am gathering all the materials required. And now, I will come straight to the point. Pay attention to my step-by-step guide and learn what you can do to make a perfect heat project with your Cricut machine.
Step 1: Design Something on Cricut Design Space
In the first step, I am using my Design Space to create my unique design. You can create your own design. I am fond of cute designs, so if they seem childish to you, you can choose from the Cricut Library.
Also, I like simplicity, so I am using only one color; you can choose from an unlimited choice of colors. One more thing: you can create your own design, and you are allowed to upload your unique design. Then, follow my next steps to learn how to use Cricut heat transfer vinyl.
Step 2: Create a Design on Design Space Canvas
When you upload your SVG file, you can follow some simple tricks using layers, grouping functions, and different colors to prepare a final image. Also, Design Space positions your graphics automatically and allows your cutting mat to cut more efficiently. In order to manage the spacing between your images, your shapes should be “Attached” in the Cricut software.
Step 3: Adjust Your Shirt Design
Now, If you want to change the layer’s color, you need to choose the image and then select the Layer option under the Layers Panel. Then, hit the colored square in the Linetype menu at the top to choose a new color. I am changing it to a teal color, like letters.
If you want to attach your letters and shapes and manage the spacing of your final projects, choose all letters and shapes in one color and hit the Attach icon under the Layers Panel at the bottom right. This option will group the letters together, and the whole design will move together when you make any changes to it.
Step 4: Preview the Final Design
Once you are ready with the design, you can check if this design is ready to cut by hitting the green Make It button. This button is at the top right corner to check your mat. On your final prepare screen, ensure that you enable the Mirror option inside the thumbnail at the left of the mats. At last, when you are done, hit the Continue button in green.
Note: When you are cutting heat transfer vinyl, you should always mirror your design.
Step 5: Load the Cutting Mat Into Your Cricut Machine
Once you are ready with your design, fix your heat transfer vinyl with the shiny side down on your green StandardGrip. Then, gently press down your vinyl to ensure that it sticks to your mat correctly and no wrinkles occur. Now, continue with the next steps to learn how to use Cricut heat transfer vinyl.
Step 6: Load Blades Into the Cricut Machine
While learning how to use Cricut heat transfer vinyl for shirts, you should know that you will have to load blades into clamp B. After that, you will need to set your cutting mat and press its Load button. When you have successfully loaded your mat and blade, hit the Go button to start cutting.
Step 7: Place the Design on Your Blank
Once your cut is complete, hit the Load/Unload button to take your mat off the machine. Next, turn your cutting mat and peel off the mat against the heat transfer vinyl. Now, weed the background of heat transfer vinyl using a weeding tool and take the small pieces of the letters.
Step 8: Pre-heat Your Blank
Before transferring the design, I would like to pre-heat my blank. A pre-heat will give your apparel warm and away from moisture and allow the heat transfer vinyl to stick well on the T-shirt. To use a Cricut Heat Press, you need to check out the Cricut Heat Guide to know the correct temperature, time, and suitable settings for your project.
I like to pre-heat my iron-on T-shirt to 315 degrees. Once you have reached the right temperature, you need to pre-heat the T-shirt for at least 5 seconds. After that, you will need to place your heat transfer vinyl on your apparel.
Step 9: Apply Heat to Your T-Shirt
When your design is fixed on the T-shirt, use your EasyPress machine on the top of your design and slightly press it down for about 30 seconds. Allow it to stand for a few seconds, and let the T-shirt cool down. And then, peel off your transfer sheet from your vinyl. I prefer to press my apparel again to ensure that my heat-transfer vinyl sticks well to the T-shirt. Once the heating is over, allow your shirt to cool, and you will be all set with your final design.
Conclusion
That’s the complete procedure of how to use Cricut heat transfer vinyl for making customized T-shirts. So, if you are inspired by my blog, you can start making your own T-shirt by printing your favorite design over it. Apply the settings as I mentioned in this blog, or if you are already an experienced user, you can experiment with the various interesting features in the Design Space. Hopefully, you liked my small guide on doing projects with Cricut and its heat-transfer vinyl.
