Apple][+ Videx Videoterm Card (80 Columns) Emulation
augusto-baffaAugusto Baffa wrote 02/08/2024 at 22:01 • 18 min read • Like
// Videx Videoterm Card Emulator
// by Augusto Baffa feb 2024
// Based on Apple II Simulator
// by Peter Koch, May 6, 1993
int videx_slot = 3;
bool card_videx = true;
bool card_videx_mem_on = false;
bool card_videx_80col = false;
class VidexCard {
    //notes:
    // To turn on/off 80 columns mode:
    // Write at 0xC058 or 0xC059
    //        card_videx_80col = (addr == 0xc059);
    // To Control the card:
    // IOSEL (0xC300-C3FFF - slot 3)
    // Read
    //        r = videxcard.getRomIoSel(addr & 0x1FF);
    //        card_videx_mem_on = true;
    // Write
    // DEVSEL (0xC0B0-C0BF - slot 3)
    // Read
    //        r = videxcard.getC0SLOTX(addr);
    // Write
    //        videxcard.putC0SLOTX(addr, val);
    // IOSTB  (0xC800-CFFF)
    // Read
    //        if (((addr >> 9) & 0b11) == 0b11) card_videx_mem_on = false;
    //        if (card_videx_mem_on && addr >= 0xC800 && addr <= 0xCDFF)
    //            r = videxcard.getSLOTC8XX(addr & 0x7ff);
    // Write
    //            videxcard.putSLOTC8XX(addr - 0xC800, val);
    // To Render:
    //for (int y = 0; y < 25; y++) {
    //    for (int x = 0; x < 80; x++) {
    //        int vkeycode = videxcard.getCSLOTXX(x, y); // get ascii code from memory
    //        bool vinverse = videxcard.isCursorPosition(x, y); // check cursor position to inverse
    //        for (int i = 0; i < 9; i++) {
    //            int video_bits = videxcard.getVideoBits(vkeycode, i); // get bits for the current char/scanline
    //            if (vinverse)
    //                display_bit_80col(renderer, x, y, ~video_bits, i); // render char/scanline
    //            else
    //                display_bit_80col(renderer, x, y, video_bits, i); // render char/scanline
private:
    uint8_t videx_rom[0x400]; // 0x0400 at C800-CBFF
    uint8_t videx_chars[0xfff]; // 0x0-0x7ff rom 1 | 0x800-0xfff rom2 character rom (12x8) Matrix)
    uint8_t videx_vram[2048]; // 0x0800 at CC00-CDFF in 4 banks of 0x1FF
    // internal variables
    int videx_bankSLOT, videx_regvalSLOT;  // active memory bank, selected register
    unsigned char videx_regSLOT[17];// registers of the CRT-controller
    //int videx_oldcursorSLOT;      // old cursor position
    //int videx_upperSLOT, videx_lowerSLOT;  // cursor size
    // Registers
    //    register r/w     normal value    Name
    //    00:      w       7B              Horiz. total
    //    01:      w       50              Horiz. displayed
    //    02:      w       62              Horiz. sync pos
    //    03:      w       29              Horiz. sync width
    //    04:      w       1B              Vert. total
    //    05:      w       08              Vert. adjust
    //    06:      w       18              Vert. displayed
    //    07:      w       19              Vert. sync pos
    //    08:      w       00              Interlaced
    //    09:      w       08              Max. scan line
    //    10:0A    w       C0              Cursor upper
    //    11:0B    w       08              Cursor lower
    //    12:0C    w       00              Startpos Hi
    //    13:0D    w       00              Startpos Lo
    //    14:0E    r/w     00              Cursor Hi
    //    15:0F    r/w     00              Cursor Lo
    //    16:10    r       00              Lightpen Hi
    //    17:11    r       00              Lightpen Lo
    // The registers are addressed as follows:
    //    To write                  To read
    //    LDA #$          LDA #$
    //    STA $C0B0                 STA $C0B0
    //    LDA #$             LDA $C0B1
    //    STA $C0B1
public:
    int getC0SLOTX(int adr)// 0x0400 at C800-CBFF
        int value = 0x00;
        //define current memory bank
        videx_bankSLOT = (adr & 0x000c) >> 2;
        if (adr & 0x0001)
            // get current register value
            value = videx_regSLOT[videx_regvalSLOT];
        else
            // define current register
            videx_regvalSLOT = value;
        return value;
    void putC0SLOTX(int adr, int value)// 0x0400 at C800-CBFF
        if (adr & 0x0001)
            // set current register value
            videx_regSLOT[videx_regvalSLOT] = value;
            //10:0A Cursor upper //11:0B Cursor lower
            if ((videx_regvalSLOT == 10) || (videx_regvalSLOT == 11))
                modifySLOT();
            //14:0E Cursor Hi //15:0F Cursor Lo
            if ((videx_regvalSLOT == 14) || (videx_regvalSLOT == 15))
                cursorSLOT();
            //13:0D Startpos Lo
            if (videx_regvalSLOT == 13)
                redrawSLOT();
            //12:0C Startpos Hi
        else
    // IOSEL READS ROM
    // when reading using iosel, adds bit at A9
    uint8_t getRomIoSel(int addr) {
        addr |= 0b1000000000;
        if (addr < 0x0400)  return videx_rom[addr & 0x03ff];
        return 0;
    // Read Video Memory using position x, y
    int8_t getCSLOTXX(int col, int row) {
        int vstart = ((videx_regSLOT[12] << 8) | videx_regSLOT[13]);
        int vcursor = ((videx_regSLOT[14] << 8) | videx_regSLOT[15]);
        int vaddr = (((row * 80) + col) + vstart) % 0x800;
        return videx_vram[vaddr];
    // Read Character Rom (Char/scanline)
    int8_t getVideoBits(int8_t keycode, int line) {
        return videx_chars[keycode * 16 + line];
    // Is cursor at defined x, y?
    bool isCursorPosition(int col, int row) {
        return vcursor == (((row * 80) + col) + vstart);
    // IOSTB - Get Rom or VRam
    int getSLOTC8XX(int adr)
        if (adr < 0x0400) // Rom is at 0x0-0x3ff
            return(videx_rom[adr & 0x03ff]);
        else
            // VRAM is at 0x600-0x7FF
            // VRAM has 0x0800 at CC00-CDFF divided in 4 banks of 0x1FF
            if (adr < 0x0600)
                return(videx_vram[(adr & 0x01ff) + videx_bankSLOT * 0x0200]);
            else //600 (or CE00-CF00)
                return(0);
    // IOSTB - set VRam
    void putSLOTC8XX(int adr, int value)
        if ((adr >= 0x0400) && (adr < 0x0600))
            int vadr;
            vadr = (adr & 0x01ff) + videx_bankSLOT * 0x0200;
            videx_vram[vadr] = value;
            //drawSLOT(vadr, value); // ignored
    void card_videx_init() {
        FILE *g;
        int i;
        int value, bits, crow, ccol;
        // Read videx rom
        printf("Loading rom: videx_firmware.rom\n");
        g = fopen("videx_firmware.rom", "r");
        if (g == 0)
            fprintf(stderr, "can't find 'videx_firmware.rom'.\n");
            exit(1);
        fread(videx_rom, 1, 0x0400, g);
        fclose(g);
        // Read videx character rom
        printf("Loading rom: videx_chars.rom\n");
        g = fopen("videx_chars.rom", "r");
        if (g == 0)
            fprintf(stderr, "can't find 'videx_chars.rom'.\n");
            exit(1);
        fread(videx_chars, 1, 0x1000, g);
        fclose(g);
        // initializing registers
        videx_bankSLOT = 0;
        videx_regvalSLOT = 0;
        videx_regSLOT[0] = 0x7b;
        videx_regSLOT[1] = 0x50;
        videx_regSLOT[2] = 0x62;
        videx_regSLOT[3] = 0x29;
        videx_regSLOT[4] = 0x1b;
        videx_regSLOT[5] = 0x08;
        videx_regSLOT[6] = 0x18;
        videx_regSLOT[7] = 0x19;
        videx_regSLOT[8] = 0x0;
        videx_regSLOT[9] = 0x8;
        videx_regSLOT[10] = 0xc0;
        videx_regSLOT[11] = 0x8;
        videx_regSLOT[12] = 0x0;
        videx_regSLOT[13] = 0x0;
        videx_regSLOT[14] = 0x0;
        videx_regSLOT[15] = 0x0;
        videx_regSLOT[16] = 0x0;
        videx_regSLOT[17] = 0x0;
        //videx_upperSLOT = 0;
        //videx_lowerSLOT = 8;
        //videx_oldcursorSLOT = 0;
        for (i = 0; i < 2048; i++)
            videx_vram[i] = i & 0xff;
    void drawSLOT(int adr, int value)
        int sadr, crow, ccol;
        // update memory pixmap
        //XCopyArea(display, charsetSLOT, memorySLOT, gc, 8 * value, 0, 8, 12, adr * 8, 0);
        // update screen
        sadr = (0x800 + adr - 256 * videx_regSLOT[12] - videx_regSLOT[13]) & 0x7ff;
        crow = sadr / 80;
        ccol = sadr % 80;
        //printf("FRAMEBUFFER [W] %d x %d = %02X {%02x}\n", ccol, crow, value, ((crow * 80) + ccol) * 8 );
        //XCopyArea(display, charsetSLOT, wSLOT, gc, 8 * value, 0, 8, 12, ccol * 8, crow * 12);
    void cursorSLOT()
        int sadr, newcursor, crow, ccol;
        // remove old cursor
        drawSLOT(videx_oldcursorSLOT, videx_vram[videx_oldcursorSLOT]);
        // update cursor
        newcursor = (256 * videx_regSLOT[14] + videx_regSLOT[15]) & 0x7ff;
        sadr = (0x800 + newcursor - (256 * videx_regSLOT[12] + videx_regSLOT[13])) & 0x7ff;
        crow = sadr / 80;
        ccol = sadr % 80;
        //XFillRectangle(display, wSLOT, xgcSLOT, ccol * 8, crow * 12 + upperSLOT, 7, lowerSLOT - upperSLOT);
        //XFlush(display);
        // remember old cursor
        videx_oldcursorSLOT = newcursor;
    void redrawSLOT()
        sadr = (256 * videx_regSLOT[12] + videx_regSLOT[13]) & 0x7ff;
        for (crow = 0; crow < 24; crow++)
            ccol = sadr + 80;
            if (ccol > 0x800)
                ccol &= 0x7ff;
                //printf("%d x %d\n", ccol, crow);
                //XCopyArea(display, memorySLOT, wSLOT, gc, 8 * sadr, 0, 8 * (80 - ccol), 12, 0, crow * 12);
                //XCopyArea(display, memorySLOT, wSLOT, gc, 0, 0, 8 * ccol, 12, 8 * (80 - ccol), crow * 12);
            else {
                //XCopyArea(display, memorySLOT, wSLOT,  gc, 8 * sadr, 0, 8 * 80, 12, 0, crow * 12);
            sadr = ccol;
        cursorSLOT();
    void modifySLOT()
        int val;
        // set upper cursor bound
        val = videx_regSLOT[10] & 0x7f; // remove blinking-flag
        if (val)
            while ((val & 0x40) == 0)
                videx_upperSLOT++;
                val = val << 1;
        // set lower cursor bound
        videx_lowerSLOT = 12;
        val = videx_regSLOT[11];
        if (val)
            while ((val & 0x01) == 0)
                videx_lowerSLOT--;
                val = val >> 1;
        // if the setting is ridiculous
        if (videx_upperSLOT >= videx_lowerSLOT)
        // draw new cursor
        cursorSLOT();
Like
