Hey, crafters fam! Welcome to my new blog post, in which I share Cricut Hat Press reviews. Reviews are really helpful for many crafters, as they can help them understand the reasons for buying this heat press machine.
Although I do the same when I have to purchase something, I always go to Google and find the reason. Be it a gadget or a machine like a Cricut cutting machine or a Hat Press, you don’t have to worry. In this blog, I will tell you all about the Hat Press machine, like why it’s the best choice for crafters.
A month ago, I was busy with my Cricut project. In this, I made my own hat using my Cricut cutting mat and Hat Press. My experience with this press was superb. Now, let’s jump aboard to learn more!
Cricut Hat Press Reviews: Overview
You might understand what a Hat Press is if you have used the Cricut EasyPress 2 or 3. The purpose of this press is the same as EasyPress; the only difference is that Hat Press is used to press the hat or cap as they have curved surfaces. It also has different temperature settings for different blanks.
In the overview, I will share the key features, specs, and pros/cons to give you a general idea of Hat Press.
Features:
- It connects via Bluetooth using the Cricut Heat app to send the temperatures and settings.
- Safe Auto shut-off feature
- Three heat settings for multiple heat-transfer ranges
- Goes up to a maximum of 400°F (205°C)
Specs:
- A product of a well-known brand named Cricut
- Connect through Bluetooth
- Measured Dimensions: Width is 6.5 inches, Height is 5.1 inches
- Weighs up to 2.4 lbs
- Zen Blue color
- Works with Infusible Ink, HTV, and more
Pros:
- Bluetooth connectivity
- Lightweight and compact design
- Automatic safe shut-off
- Easy-to-reach buttons
Cons:
- There is no bag for storage
- Apt for smaller designs
- Its curved heat plate does not allow us to work near the brim of the hat
- The cost is high for occasional users, and it is used only for hats
Cricut Hat Press Reviews: Technical Specifications
If you are a Cricut EasyPress 3 user, you will notice a few similarities between these two devices. This press excels at transferring infusible ink, iron-on heat transfer vinyl (HTV), and sublimation paper. It also reaches a maximum temperature of up to 400 ℉ (205 °C).
Now, let’s move ahead to learn the technical specifications of Hat Press:
Cricut Heat App
Do you know you will need to use a Cricut Heat app to activate your Hat Press? For this, you will need to download the app and then sign in to your Cricut ID.
However, the on-screen instructions were really helpful when I was setting up my Hat Press.
Here’s a glimpse of the Cricut Hat Press activation via the Heat app:
Working With Iron-On
When I used my Cricut Hat Press with iron-on to make hats, the overall experience was quite satisfying. The final result was also as per my expectations. During the process, the Cricut Hat Press Guide taught me general guidelines to complete my projects as quickly as possible.
In addition, when you use it with Cricut’s Smart Materials and Cricut’s newer machines, the process will feel very fluid, meaning you won’t find it boring or tedious.
Working With Infusible Ink
For me, the more advanced trial is to use this Infusible Ink for my hats. Also, it allows you to use a wide range of colors, making you focus attentively so you don’t mess up paper layering to prevent bleeding.
However, for better guidance, you will need to rely on the Cricut Heat app for some guidance. As a result, it will guide you in layering your design properly.
In short, this is the best option for those who want the multi-layer colors on their hats.
So, these Cricut Hat Press reviews might have helped you understand the reason so that you can decide to get this Cricut Hat Press machine.
FAQs
Can I use any hat with my Cricut Hat Press?
Cricut has designed its Hat Press in such a way that it can transfer the design to all types of hats. However, if you want to see the best results, then make sure your hat blank fits smoothly over your hat-pressing form. Also, you have to ensure the press surface has firm pressure so no bumps remain on the pockets between your hat and the pressing form.
Why do I need a Cricut Hat Press?
This heat press is specially designed to transfer your infusible or vinyl design onto your blank hat. Since hats are curved, this machine also comes with a curved surface plate coated with ceramic. Also, there are three levels up to 400° F. (2.5°C). Besides, you can use it for any hat, such as adult-size hats, sun hats, and ball caps.
Is Cricut Hat Press really worth buying?
As per my crafting experiences, I can assure you that it is a really useful Cricut accessory. If you are a sports lover or you want to start a small venture that sells customized caps or hats, then you can get this device so that you can transfer the design onto the hat. This Cricut Hat Press transfers the design really amazingly. Hence, yes, it is worth buying if you need to use it repeatedly.
Wrap Up
That’s all in Cricut Hat Press reviews. In this guide, I have discussed many points, such as key features, specifications, and the pros and cons, which help you decide whether it is worth buying or not. Besides, there are technical specifications that you must know as they will help you understand the working process of your Cricut Hat Press along with iron-on and infusible ink materials. So, find a suitable reason to get this Cricut Hat Press machine.
For more information visit: Cricut.com setup mac
install cricut design space app
Source: Cricut Hat Press Reviews
