![](https://cricutair.files.wordpress.com/2024/03/how-to-cut-wood-with-cricut-a-step-by-step-guide.png)
Wood is a perfect material for creating unique and long-lasting designs. I have been using the Cricut machine setup for a long time and have gained an appreciation for my wood projects. My best friend and I recently made some awesome home decor for our bedrooms and halls. And you know what? They turned out to be nice handmade pieces. But one thing we found tedious was cutting wood. Since my friend was new to Cricut wood projects, she struggled with cutting and moving forward. Luckily, I helped her cut wood with Cricut and ended the project nicely.
Moreover, I have seen many beginners need help cutting wood using a Cricut machine. With all these in mind, I am here with a useful tutorial to help crafters cut wood. Dive into this blog post and learn the step-by-step process.
Step 1: Getting the Right Tools and Supplies
Have you planned to get started with a wood project? First of all, you will need to gather all the essential equipment. Take a look at a few of them below.
Cricut Machine
Initially, you will need to have a Cricut machine. You can have a Cricut Maker for this purpose. Do you need to learn how to cut wood with Cricut Maker? You can do it effortlessly. This machine has new technology to help you with an efficient cutting process. One of the best things you can find in this machine is the Drive Housing.
Knife Blade
A knife blade is an important tool for cutting wood material. It goes excellently with cutting plywood and other tough materials. This blade goes multiple runs while you try to slice a thicker material. So, you can be assured of precise cutting when you use a knife blade. It included a light score pass, a lighter pass, and a heavier pass in the center to bring out nice-cut results.
Material (Wood That You Want to Cut)
You can purchase some wood material that is designed to work with a Cricut machine. This way, you can cut wood with Cricut and create DIY projects. Either go to a local store or go online to get wood material. You will only need to ensure that your machine is compatible with the material.
Step 2: Preparing Your Cricut Machine
The next step in cutting wood is preparing a Cricut machine for cutting. Here are some simple instructions to assist you with the cutting process.
- First of all, move to your Cricut machine.
- After that, grab the knife blade and load it into your machine.
- Now, find the roller bar on your Cricut.
- Then, slide the white star wheels until it comes to the right side.
- Further, ensure that the black rubber wheels will move your Cricut mat.
- Finally, put in some force to slide the white wheels properly.
You need to perform these steps while preparing your Cricut machine for cutting. But, this cut wood Cricut tutorial for beginners still needs to be completed. You will need to proceed with the one last step, i.e., start cutting wood.
Step 3: Start Cutting Your Project
The final step of cutting wood is the cutting process itself. You will be required to cut the board in these steps. So, start the process using the steps below.
- Start by creating a pass in the middle of the cutting files.
- The Cricut Design Space Software will start preparing to cut the wood.
- Next, your Cricut machine will start slicing the wood in multiple passes.
- In the next step, ensure that your sheet is completed or not.
- If not, run an additional pass.
- Next, look at your mat and the wood material.
- Further, if you can lift the wood, the process is complete.
- After that, move to Design Space on your system.
- Finally, eject your mat from the Cricut machine.
These are the three basic steps that you can follow to cut wood with Cricut. So, while you try to cut the material, follow them carefully.
What Do You Do When a Cricut Knife Blade Doesn’t Cut the Material?
Sometimes, the knife blade can fail to cut through the wood material. If this is your case, you must proceed with some further steps. Remember to retrieve the pad from your Cricut machine once all passes have been proceeded. In addition, follow these helpful steps.
- First, remember to keep the mat if there are some necessary cut passes.
- Next, use a weeding tool and examine your material cuts.
- After that, use a tiny hand tool if you find that a section needs more slicing.
- Thereafter, navigate to the Go icon in the Cricut Design Space.
- Start further phases for a smooth cut.
- It is your job to decide whether the material needs additional passes.
- Finally, use an X-acto knife tool to finish off these cuts.
These valuable steps will help you with cutting material precisely.
Conclusion
Wood is a great material you can use for creating numerous DIY projects. After all, these help make projects everlasting and creative. If you are a beginner crafter, you can learn how to cut wood with Cricut and begin with the projects you have in mind. The process includes three key steps. These are gathering the right tools and materials, preparing the Cricut machine, and starting the cutting process. Proceed carefully with the process and take your crafting creativity to newer heights.
Frequently Asked Questions
What Wood Should Crafters Use in Cricut?
Crafters can start crafting with the two most common varieties of wood, basswood and balsa wood. These two wood varieties are lightweight and work great in creating various handmade crafts.
- Balsa Wood: Balsa is the cheapest option, and you can find it readily available at craft and other related stores.
- Basswood: It is thicker and stronger than balsa. Please note it is not prone to warping. Moreover, the Cricut machine’s knife blade works while cutting through it.
How to Cut Wood with a Cricut Maker?
Do you have a Cricut Maker machine? Find below a few steps to cut wood with Cricut Maker.
- In the initial step, go to Cricut Design Space.
- Next, tap on Make It.
- After that, move to your Cricut Maker and tap on Go.
- Run the cut passes according to the size and complexity of your project.
- Now, eject the cutting mat.
- Double-check your cut result.
- Peel the mat from the material.
How Do I Cut Wood With Cricut Explore Air 2?
If you have Cricut Explore Air 2, you can cut wood and do exciting wood projects. Follow these easy-to-follow steps.
- Go to the Cricut Design Space app and make a design.
- Set your machine’s dial to custom settings.
- Now, place your material on the mat.
- Insert the cutting mat and tap on the Go button.
- Double-check your cut results.
- Finally, remove the mat and the tape.
For More Information Visit: cricut.com setup windows
Source: Cut Wood With Cricut
