Hackaday reports that OnChip launched a Crowd Supply campaign:
mRISC-V: The First Open Source RISC-V Microcontroller
Now, this is finally changing. OnChip, a startup from a group of doctoral students at the Universidad Industrial de Santander in Colombia, have been working on mRISC-V, an open 32-bit microcontroller based on the RISC-V instruction set [..]
![cx4qfdhw8aa7ih-jpglarge](https://blogdotoshparkdotcom.files.wordpress.com/2016/11/cx4qfdhw8aa7ih-large.jpg?w=660)
Open-V Chip Specifications
- Package
- QFN-32
- No other packages are planned for the first run
- Processor
- RISC-V ISA version 2.1
- 1.2 V operation
- Memory
- 8 KB SRAM
- Clock
- 32 KHz – 160 MHz
- Two PLLs, user-tunable with muxers and frequency dividers
- includes all clocking and bias circuitry
- Analog Signals
- Two 10-bit ADC channels, each running at up to 10 MS/s
- Two 12-bit DAC channels
- Timers
- One general-purpose 16-bit timer
- One 16-bit watch dog timer (WDT)
- General Purpose Input/Ouput
- 16 programmable GPIO pins
- two external interrupts
- Interfaces
- SDIO port (e.g., microSD)
- Two SPI ports
- I2C
- UART
- Programming and Testing
- Built-in debug module for use with gdb and JTAG
- Programmable PRBS-31/15/7 generator and checker for interconnect testing
- Compatible with the Arduino IDE
![onchip-dev-board-render_jpg_project-body](https://blogdotoshparkdotcom.files.wordpress.com/2016/11/onchip-dev-board-render_jpg_project-body.jpg?w=660)
Open-V Dev Board Specifications
The dev board comes completely assembled.
- USB 2.0 controller
- 1.2 V and 3.3 V voltage regulators
- Clock reference
- Breadboard-compatible breakout header pins
- microSD receptacle
- Micro USB connector (power and data)
- JTAG connector
- 32 KB EEPROM
- 32-pin QFN Open-V microcontroller
- Dimensions: 55 mm x 30 mm (excluding USB receptacle)
