I will use LoRaWAN as protocol of communication, so Frequency is 868 MHz , the data rate is low, low bandwidths are required. A variety of Bandwidths are available: 7.8 kHz; 10.4 kHz; 15.6 kHz; 20.8 kHz; 31.2 kHz; 41.7 kHz; 62.5 kHz; 125 kHz; 250 kHz; 500 kHz (the most frequently used frequency bands are 125kHz and 250kHz).
Exactely Stuart, i will install the antenna in homes and fields .
What frequency band?
