Good Servos For Hexapod
ActualDragon wrote 04/06/2017 at 17:03 • 1 point2 years ago when I started my hexapod, I didn't have to much cash to spend, so i bought 12 of these https://hobbyking.com/en_us/turnigytm-tgy-s901d-ds-mg-robot-servo-13kg-0-14sec-58g.html from hobbyking. When I got them, one broke in a year, and the rest aren't that accurate. Then again, $10 is pretty cheap. I'm getting a summer job this year, and am in the market for an upgrade. I found this servo https://hobbyking.com/en_us/hxt-10kg-servo-metal-gear-10kg-0-16sec-55g.html, and it's like 325 oz/in. It's only $8 tho, so it's probably a downgrade. I need at least a 100 oz/in torque, and would like it to be max $20. Any tips?
the mini dynamixels will save you a lot of headaches.
If precision is what you are looking for then a stepper motor would be your answer. but if you are looking for a servo then check out Tower Pro servos. They have a wide range and some fit your description.
