Servo Shield for OpenMV
oshparkoshpark wrote 04/18/2017 at 02:57 • 2 min read • Like
Radomir Dopieralski created this PCA9685-based servo shield for the OpenMV machine vision board:
4138171491641694458
OpenMV has a couple of pins that you can use for connecting servos (for example, if you want to mount it on a pan-and-tilt base), but you can’t use those if you also want to use the WiFi shield or any other shield that uses up a lot of pins. Practically the only pins left to use are the I²C ones
deshipu has shared the board on OSH Park:
OpenMV Servo Shield
e78e5b88d0df930c5691ccdb68e7f192
Order from OSH Park
Like
