Trying to make [this] work with the Arduino IDE on a Wemos D1 Mini. The additional capacitor got loose, so that there were fluctuations in one row. One row seems to be dead now, after I tried to resolder the QFN chip with my soldering iron. Instead of fiddeling around with that anymore, I finally got around to fix my hot air station. One of the 230V cables was crimped wrong, there was still some isolation where there should have been the blank cable, I wonder why it ever worked at first. There's a DIP Atmega8L inside - funky.
#include <Wire.h>
byte address = 0x50;
void setup() {
Wire.begin();
activate();
void loop() {
ledPWM(255);
delay(1000);
ledPWM(0);
delay(1000);
void ledPWM(byte b)
// Wire.write(byte(0x00));
for (byte i=0; i<98; i++)
writeEnable(byte(0x01));
Wire.beginTransmission(address);
Wire.write(i*2);
Wire.write(b);
Wire.endTransmission();
void turnOnLeds()
writeEnable(byte(0x00));
for (byte i=0; i<12; i++)
Wire.write(byte(0x55));
Wire.write(byte(0x15));
void releaseRegister()
Wire.write(byte(0xfe)); // send command
Wire.write(byte(0xc5)); // send page zero
void writeEnable(byte page)
releaseRegister();
Wire.write(byte(0xfd)); // send command
Wire.write(page); // send page zero
void activate()
writeEnable(byte(0x03));
Wire.write(byte(0x00)); // Configuration Register
Wire.write(byte(0x01)); // Set SSD = 1
Wire.write(byte(0x01)); // Global Current Control
Wire.write(byte(0x30)); // set to 127
turnOnLeds();
davedarko
