SSD1306 1.3″ OLED SPI breakout board
oshparkoshpark wrote 07/26/2017 at 16:00 • 2 min read • Like
Rene van der Meer designed this breakout board for a bare OLED display:
I’ve been playing with cheap OLED display breakouts for years, incorporating complete boards into my projects – an easy, but bulky solution. Now that I’ve had some practice designing circuits and PCBs, it’s time for my next challenge: soldering the display FPCs directly to my own boards.
ssd1306spi-10a-sch
I designed this board to try out a minimal circuit before integrating it into any larger projects, and to figure out the best way to solder flexible circuits to my boards. Since all of my new microcontroller-powered board designs only require 3.3 V, I haven’t added any 5 V tolerant level shifting. What’s left is a bare minimum circuit to drive a Solomon Systech SSD1306 using SPI at 3.3 V.
ssd1306-10a-back
golemparts has shared the board on OSH Park:
SSD1306 SPI Breakout v1.0 A
15d3c74ba0338db3d3a4469e58673f9b Order from OSH Park
Like
moosepr wrote 07/26/2017 at 16:42 point
By Jingo that is simple!!! Does that screen not need the 13v boost then?
oshpark wrote 07/27/2017 at 02:46 point
It seems that it does not.  The product page that: "only a single 2.8V power supply is needed"
http://www.buydisplay.com/default/serial-spi-1-3-inch-128x64-oled-display-module-ssd1306-white-on-black
