Asset Tracker
oshparkoshpark wrote 08/06/2017 at 19:13 • 3 min read • Like
@Kris Winer designed this is a small 4-layer PCB for remote logging of absolute position and orientation:
Asset Tracker
STM32L433-based board with CAM M8Q concurrent GNSS, EM7180 + MPU9250 + MS5637 for absolute orientation, and an ESP8285 for wifi connectivity.
https://hackaday.io/project/25790-asset-tracker https://hackaday.io/project/25790-asset-tracker
The board uses an STM32L433 Cortex M4F host programmable via the USB connector using the Arduino IDE and an Arduino core created by Thomas Roell . The absolute position engine is a UBLOX CAM M8Q concurrent GNSS module connected to the STM32L433 via UART. The CAM M8Q uses a chip antenna so no external wire or patch antenna is required resulting in a very convenient device package. The pcb is an integral part of the CAM M8Q antenna and the pcb has been sized to meet the minimum ground-plane size recommendations (20 mm x 45 mm).
The absolute orientation engine uses the MPU9250 accel/gyro/magnetometer IMU sensor plus the MS5637 barometer as slaves to an EM7180 motion co-processor that sends quaternions and drift-stabilized altitude to the host via I2C.
https://hackaday.io/project/25790-asset-tracker https://hackaday.io/project/25790-asset-tracker https://hackaday.io/project/25790-asset-tracker
There is an Arduino library and sketch available on GitHub:
kriswiner/AssetTracker
PeskyProducts has shared the board on OSH Park:
AssetTracker.v02c
a12067ff0680dc9f13a9933a8bb07507
Order from OSH Park
Like
