If you are a crafter, you may always wonder which machine is the best and which is not. I can totally relate to you. When I started out as a crafter, I was greatly influenced by the internet, people, and friends. But there was one blog that really helped me make the right choice for me. So, if you are on the same page as I was, I am in your rescue. When you are looking for the Best Cricut machine, you should not think twice about it as these machines are amazing.
Through this guide, I will be telling you about the top 3 Cricut models that have been game-changers for most crafters and that can become a milestone for you, too. I am gonna talk about Cricut Maker, Cricut Explore, and Cricut Joy. All of these machines are old models, but they are very suitable for newbies. Let’s understand what these tools are.
1. Cricut Joy
This is really a fun machine that makes your crafts perfect and provides precise cuts and draws excellently. Also, it can use the Cricut Design Space software, a personalized software for all the Cricut machines. You can use many interesting designs from the Design Space Library and use them in your projects.
![](https://media.selfmade.com/images/cricut-joy-machine-74155-sskit.jpg?width=1600&height=1600&i=83826&ud=apzcfqbp2wg)
This excellent machine is compact and portable and measures 5” x 5” x 8”. Plus, it uses a wide range of Cricut materials to cut, including Smart Materials. Also, it’s the only machine that uses a card mat for making multiple cards simultaneously.
However, you can’t make bigger projects on a Cricut Joy and cut hard materials such as wood, fabric, chipboard, etc. Also, you can’t use the Print then Cut feature on it. So, overall, this machine would be a perfect fit for crafters who want instant crafts. So, if you are a teacher, mother, or student, Cricut Joy can be the best Cricut machine for you.
2. Cricut Explore Air 2
This is another machine on my list. However, this machine is big and can be used for complex projects. With a colorful lineup and elegant design, it attracts a large number of people. It is capable of cutting more than 100 materials easily with its sharp blades and impressive build-up. It needs a cutting mat of at least 12” x 12” to cut different materials.
Explore Air 2 can cut lots of materials, but it can’t cut thicker and harder materials like wood, leather, and fabric. In addition, it doesn’t allow matless cutting and can’t use Cricut Smart Materials. So, whoever has a minimal project requirement can use this machine.
![](https://cdn.shopify.com/s/files/1/0070/5173/9189/files/195119-Air_2_Mint_Machine_Lifestyle-001_600x600.jpg?v=1697863733)
3. Cricut Maker
Here comes the strongest Cricut machine that has various impressive features and can cut a wide range of materials. But why is it the best Cricut machine? All thanks to its powerful tools like blades and housing. Well, the tools of the Cricut Maker are interchangeable with that of the Cricut Explore. Hence, you can use them on both of these machines to perform engraving, debossing, engraving, and many more things.
![](https://cricut.com/dw/image/v2/BFRQ_PRD/on/demandware.static/-/Library-Sites-cricut-content-global/default/dwc981b74f/PDP/SeeWhatItCanDo/Maker3_SeeWhatItCanDo_Desktop_1_2x.jpg)
Plus, the machine is known for its advanced cutting features and compatibility with a wide number of materials, from delicate to complex, such as fabric, wood, and even leather.
Hence, it’s clear that this machine is already ahead of the competition in every aspect and can deliver work faster and better than any other Cricut machine.
However, this machine doesn’t facilitate matless cutting. Apart from this, there is no point where this machine doesn’t persuade the users. Overall, this machine would be a perfect fit for serious crafters who are driven to create something unique.
Which Cricut Machine Should You Consider?
Since all the Cricut machines are pretty good, you need to decide what your expectations are as a crafter. So, when you are searching for the best Cricut machine for crafts, you must understand what type of projects you are gonna make. So, if you are a seasonal crafter and rarely need a cutting machine, you can get a Cricut Joy that will match your needs and offer you flexibility.
![](https://cricut.com/dw/image/v2/BFRQ_PRD/on/demandware.static/-/Library-Sites-cricut-content-global/default/dw54901ef3/images/homepage/3_WIC_3up_2x.jpg)
But, if your purpose is to create unique projects with your machine, you must consider Explore Air 2. And lastly, if your expectations are high and you want advanced results, a Cricut Maker would be more than enough for you.
I have shared everything a beginner should know before considering a Cricut machine to start crafting. Now, you can decide freely what your expectations are. And you can get a suitable machine for your work.
Conclusion
I have shown you all the best Cricut machines to select as a beginner. You can select one according to your specific crafting goals. So, if you can find the best Cricut machine for beginners, it will be great to start with. According to me, all the Cricut machines are ideal for getting started as a beginner. Whether you select Cricut Maker, Explore, or Joy, all of them will work great for you as per your needs. I hope you have found your best machine in 2024.
Visit: cricut.com/setup
install cricut design space app
Source: https://explorenewmachine.com/which-is-the-best-cricut-machine-you-should-buy-in-2024/
