You all are here to learn how to use the Cricut Explore Air 2. I have been using this machine for a long time, and it has been my all-time favorite crafting tool. You all must be wondering about its setup and usage, so I want to tell you that it’s very simple, and you will be amazed by its excellent features and performance.
In this blog, I will tell you all the basics about the latest Explore Air 2. Although Cricut has made various tools, some machines, like Explore Air 2, are best sellers. To learn more about the machine and its uses, read this blog till the end and learn everything here. With the help of this blog, I will teach you how to use Cricut Explore Air 2 for beginners.
What Is a Cricut Explore Air 2?
Cricut Explore Air 2 is the latest machine from Cricut that is so brilliant that it can cut over 100 materials and can make 3000+ ready-to-make projects in the Design Space software. If you are a Cricut user, you already know the Cricut Explore Air 2 setup that includes Cricut Design Space.
You can either make designs in the Design Space or upload an external file into it. Also, you can use other programs to make designs, including Adobe Illustrator and Canva. Plus, you can upload your own fonts, too.
If your requirement is to do some bigger projects for personal or professional use, an Explore Air 2 would be an ideal option. Now, let’s move on to the following process to learn how to use the Cricut Explore Air 2.
What Can I Cut With Cricut Explore Air 2?
Since I have been using the Explore Air 2 for so long, I have tried different materials with it. Basically, it can cut light to hard materials like paper, vinyl, cardstock, etc. So, this machine is no more than a powerhouse that can cut a range of materials easily. However, you will need some special type of blades, such as deep blades, to cut those materials.
How to Use the Cricut Explore Air 2 to Make a Paper Flower?
When you know about the Explore Air 2 machine, it’s time to create a project out of it. So, here I am going to tell you how to make large paper flowers with your Cricut.
If you are ready, arrange a large paper of about 12” x 12” to make bigger flowers, and you can also adjust the size as per your choice. If you are confused about where to buy the cardstock, don’t worry; you can get them from a local craft store easily.
Step 1: Supplies and Tools You Need to Get Started
When you have decided to make a large paper flower with your cardstock, you’ll need to arrange a few items, as I have listed below.
- Brand new Cricut machine
- StandardGrip mat
- Wonder clips
- Craft glue
- Fine point blade
- Scissors
- Pencil
- Printer
- Dowel
When you all are ready with these items, let’s continue with my guide on how to use Cricut Explore Air 2.
Step 2: Download a Paper Flower Template From Design Space
You need to get the template for this design under the Design Space Library. Use it to get a perfect design template for you. Once you find the design, you should cut it with your Cricut Explore Air 2 machine. Once you are done, see how to use the Cricut Explore Air 2 to make a large flower design.
Step 3: Cut Your Flower Design
When you are ready with the design, you need to cut it. To do it, load the cutting mat with cardstock into the Explore Air 2 and allow it to cut your design. Once the final design comes out, you can continue with the further steps.
![](https://cricutspaces.files.wordpress.com/2024/02/how-to-use-the-cricut-explore-air-2-ultimate-guide.jpg?w=976)
Step 4: Assemble All the Pieces
When you get the final cut, it’s time to assemble them. Collect similar petals together. Once you assemble them together, you are good to go to learn how to use your Cricut Explore Air 2 to make a flower project.
Step 5: Overlap the Petals
In this step, you need to use craft glue to overlap the petals from the bottom to create a petal-like dimension. Apply the glue at the bottom of your petals. To make the petals glued correctly, you can use wonder clips to hold them. So, I am using a bunch of wonder clips here to hold my petals.
![](https://cricutspaces.files.wordpress.com/2024/02/how-to-use-the-cricut-explore-air-2-ultimate-guide1.jpg?w=987)
When the glue is dried up, you will see a small line at the bottom of your petal due to overlapping, but it will be covered with another layer of petals, so don’t worry about it.
![](https://cricutspaces.files.wordpress.com/2024/02/how-to-use-the-cricut-explore-air-2-ultimate-guide2.jpg?w=980)
Step 6: Align Petals in the Form of a Ring
When the glue is dried up fully, you need to arrange the petals in the form of a ring around a circle to check how many petals it’ll take to make a flower. Then, glue all of those petals together to make a flower layer. On this layer, you can add more petal layers.
![](https://cricutspaces.files.wordpress.com/2024/02/how-to-use-the-cricut-explore-air-2-ultimate-guide3.jpg?w=979)
![](https://cricutspaces.files.wordpress.com/2024/02/how-to-use-the-cricut-explore-air-2-ultimate-guide4.jpg?w=963)
Step 7: Add More Petal Layers in the Center
After creating one layer, you can add more layers in its center to create a bulky flower design. Add different colored petals to make a complete flower. At the end, I am adding a yellow flower. It was a beautiful project that you can make with your Cricut Explore Air 2 machine.
![](https://cricutspaces.files.wordpress.com/2024/02/how-to-use-the-cricut-explore-air-2-ultimate-guide5.jpg?w=938)
![](https://cricutspaces.files.wordpress.com/2024/02/how-to-use-the-cricut-explore-air-2-ultimate-guide7.jpg?w=870)
Conclusion
Finally, you have learned how to use the Cricut Explore Air 2 to create a beautiful project. I know it’s something new to make but trust me, it’ll look best at your home. It’s one of the graceful decorative items you can create with your Cricut machine. Well, there are many options to try with your Explore Air 2, and you will get more such projects in my further blogs.
Visit: cricut.com/setup
install cricut design space app
Source: https://cricutspaces.wordpress.com/2024/02/21/how-to-use-the-cricut-explore-air-2-ultimate-guide/
