Hey, are you looking for a guide to setting up your Cricut machine? However, Cricut already has plenty of models in its lineup. So, which Cricut machine am I talking about?Well, this is going to be all about the Cricut Explore Air 2 wireless setup. The setup will be done wirelessly using Bluetooth. Since a Bluetooth connection might be a little tricky for beginners, I will show you how to connect your Cricut Explore Air 2 to Windows or Mac wirelessly via Bluetooth.
I have done it for many Cricut machines, such as Cricut Maker, Explore, and Joy. But today, I am setting up my friend’s machine. She wanted to enter the world of crafting, so she had to do it herself, but for some reason, she could not do so. I took this chance to explain to you all the steps of setting up the machine. Let’s start!
How to Connect Cricut Explore Air 2 via Bluetooth to Computer?
Let’s establish the connection here! Connection is very important for our Cricut Explore Air 2 wireless setup. The wireless connection will be a breeze with the following steps:
Windows
- You should first place the Cricut machine within 10 to 15 feet of your computer.
- Then, you will need to move to the Start menu > Settings (Gear icon).
- After that, you need to go to the Devices option.
- Now, turn on Bluetooth and hit Add Bluetooth or other device.
- Next, select Bluetooth and wait until it shows your Cricut model.
- Also, select the machine from the available list.
- Here, your machine will be paired.
- You can also start setting up your machine.
Mac
- The first step is the same as for the Windows computer.
- Navigate to your Apple menu and select System Preferences.
- Now, you have to find the Bluetooth option.
- Verify whether the Bluetooth is turned on.
- Then, let your Mac find your Cricut machine.
- Select the machine model found by your Mac and begin pairing.
- Finally, you have paired your machine successfully.
iOS
- Again, the first step is the same as that for Mac or Windows.
- Now, go to the Settings and turn on the Bluetooth.
- Now, choose your Cricut model from the list.
- Now, you have paired your Cricut Explore machine with your iOS device (iPhone or iPad).
Android
- Once you have placed your machine at a recommended distance, you need to go to Settings.
- Now, you have to turn your Bluetooth on.
- Then, select your machine model from the available list.
- Here, it is paired now.
Cricut Explore Air 2 Wireless Setup on a Computer
Below, I will share the methods for wirelessly setting up your Cricut machine. The following steps will be helpful for both Mac and Windows users.
- To setup your machine, you have to visit cricut.com/setup on any browser that you use.
- Then, proceed to the next page and click on the check box to download the Cricut Design app.
- However, everything will be shown on the screen; you just have to follow the prompts to set it up.
- Next, you will be required to register your machine using sign-in with your Cricut ID.
- Afterward, choose the machine on the upcoming screen.
- Now, you have to plug your machine into your computer using your power cord.
- You can skip to the next step since you have already connected via Bluetooth.
- Also, your Design Space will be updated; wait and let it update.
- Once it is updated, you have to register your machine by entering the details. You should also try the free Cricut Access Membership trial.
- Finally, you have to follow the prompts to perform a test cut or complete your first project.
Cricut Explore Air 2 Wireless Setup on a Mobile
Many users want to use their mobile phones to operate or setup the Cricut machine. Don’t worry; I’ve got you covered below! Below, I have explained how to setup Cricut Explore Air 2 for mobile devices, suitable for both iOS and Android devices.
Here are the steps to setup the Cricut Explore cutting machine on a mobile device:
- Go to your Google Play Store or App Store to download the Cricut Design Space.
- Now, you will have to open the app and register with your Cricut account.
- Go to the Menu on Design Space and select the Machine Setup option.
- After that, plug your Cricut machine using a power cord and turn the machine on.
- As you have already paired your phone above, you can skip to the next steps.
- Now, your Cricut cutting machine setup is complete.
Finally, you have completed your first Cricut Explore Air 2 wireless setup in no time. Now, embark on your crafting journey tirelessly!
FAQs
Question 1: What do I need to setup my Cricut machine?
Answer: You will need the following things to setup the Cricut cutting machine:
- Power cord – It is used to plug your machine into the power source.
- USB cable – To connect the Cricut product to a computer.
- Cricut ID – Register the machine.
- Cricut Design Space – You can create intricate designs.
- Fine Point Blade – To make cuts
- Cricut Infusible Ink Transfer Sheets – This is for making projects during test cuts.
Question 2: Which software should you use to setup Cricut?
Answer: Cricut Design Space is software downloaded while setting up the Cricut machine. After you have completed the downloading process, you need to follow the on-screen instructions for the Cricut software. Cricut’s website also provides the system requirements to help you decide whether your device is compatible with running your software.
Question 3: Does it cost anything to set up a Cricut machine?
Answer: No, it doesn’t! Cricut never charges a single penny for machine setup. Whether you want to setup your Cricut cutting machine or heat press, you can simply visit cricut.com/setup. On this website, you will first download and install the Cricut Design Space app which is also available for free. So, you don’t worry and setup the machine anytime freely.
Visit: install cricut design space app www.cricut.com setup login
Source: https://explorenewmachine.com/cricut-explore-air-2-wireless-setup-on-a-computer-and-mobile/
