If you are using a Cricut machine, it is obvious that you know about the Cricut Design Space app. And you are here just to learn how to start with Cricut Design Space Mac? Well, I can help you use this Cricut software on your Mac computer. I have a small Cricut business, and I am an expert in using the Cricut machine along with its software. Before starting my DIY shop, I used to make many projects and sold some of them on online websites. I understand the need for this software in crafting and thus decided to create a useful post for all crafters.
Through this post, my aim is to help Cricut users use its app on their Mac computers. Thus, I will cover the minimum system requirements for Mac, plus the downloading and installation steps for the software. So, you will find this post helpful when using the Cricut software on a Mac computer.
Cricut Design Space Minimum System Requirements for Mac
Do you have no idea you need to know the system requirements to use the app on your system? Mac users can look into the criteria below and find whether the app is able to work on their systems or not. If they fail to meet, the app will not work on their devices.
- macOS 11 or later versions are needed.
- CPU should be 1.83 GHz.
- RAM needs to be at least 4 GB.
- Free disk space of a minimum of 2 GB should be available.
- Either a Bluetooth connection or a USB port is available.
- Display with minimum 1024px x 768px screen resolution.
If your Mac device fulfills the above requirements, you can move further with learning how to use Cricut Design Space on Mac. I will cover the downloading and installation process of the Cricut app in the next section.
Cricut Design Space Mac Download
After you know that your system is compatible with the Cricut software, you can move on to your next step by downloading it to your system. I am listing below a step-by-step process that helps you download the app quickly and hassle-free.
- At the beginning of the process, move to your Mac computer and power it on.
- In the next step, go to the search bar on your Mac device's browser.
- Now, your Cricut machine will start finding the operating system you are using.
- You will now see yourself on the Cricut website.
- On the website, look for the I Agree option.
- Next, make sure to check the box and tap on Download to begin the procedure.
- A Download icon will appear on the page.
![](https://cricricutdesigncut.files.wordpress.com/2024/04/cricut-design-space-mac6.png?w=854)
- After you see the Download icon, click OK and follow the steps to download.
- Finally, the Cricut app downloads to your Mac computer.
Did you download Cricut Design Space Mac successfully on your Mac computer? You can now move next to install the downloaded Cricut file on your system. To do this, read the next section of this blog, which includes steps to install the app.
How to Install Cricut Design Space on Mac?
If you want to use the Cricut Design app on your Mac system, read the given below steps and follow them carefully. This helps install the software efficiently on your system.
- When you start to download the file, go to your Mac system first.
- Next, go to the browser in your system.
- You can also find the downloaded file in your Mac's destination folder.
- Thereafter, you need to drag the file to your Applications folder.
![](https://cricricutdesigncut.files.wordpress.com/2024/04/cricut-design-space-mac1.jpg?w=646)
- Try to find the Cricut Design app in your Applications folder.
- Click on the Cricut symbol in the Applications folder.
![](https://cricricutdesigncut.files.wordpress.com/2024/04/cricut-design-space-mac2.jpg?w=664)
- The above steps will move you toward installing those files.
- Then, a notification will appear saying to trust the application.
- When the notification appears, click on Yes.
Now, after you install the Cricut Design Space Mac application, your job is not yet over. You will now have to create a User ID or start logging into your Cricut account.
How to Log Into a Cricut Design Space Account?
Cricut and Mac users can log into the Cricut app and start creating their favorite projects in a time-saving way. But the question is how they can do it. Check the steps mentioned below.
- At the start of the process, go to your Mac device and try to open the app.
- In the following step, click on the Get Started button once you see it.
- After you go to the next screen, there is a display asking you to enter your details.
- Enter your first plus last name.
- Then, enter your email address.
- Next, type in the name of the country you are living in.
- Click on the Create User ID option.
![](https://cricricutdesigncut.files.wordpress.com/2024/04/cricut-design-space-mac3.jpg?w=790)
- A screen will display that shows you have created a Cricut account.
- After that, hit the Continue button.
- Open the Cricut app and go to the Cricut account login page.
![](https://cricricutdesigncut.files.wordpress.com/2024/04/cricut-design-space-mac4.jpg?w=397)
- In the end, you can log in to your Cricut ID.
With these steps, you can simply use the Cricut software on your Mac system and begin crafting in an efficient and time-saving way. Start with the Cricut Design Space install on Mac free and login to start crafting.
Conclusion
Cricut Design Space is easy to use on a Mac system. DIY makers or professional crafters who want to create projects quickly can use this software and create projects efficiently. The process of Cricut Design Space Mac includes the steps to download and install the software on a system. Thus, ensure to download and then install it and then create a Cricut account. Old users just need to log into the app.
Frequently Asked Questions
What Cricut Machines Can I Use With Mac to Download Cricut App?
A Mac computer and Cricut user needs to check the minimum system requirement and then plan to use the Cricut app. The list of some machines that work with the Cricut Design app are:
- Cricut Maker and Maker 3
- Cricut Joy and Cricut Joy Xtra
- Cricut Explore, Cricut Explore 3, and Cricut Explore Air 2
How Can I Setup Cricut Machine With Cricut Design Space?
Cricut Design Space setup is easy, and thus, you can do it without much effort. To start with, here are a few steps.
- Find the cable of your Cricut machine and plug it into the socket.
- Then, grab the USB cable or use Bluetooth to connect your machine to the system.
- You have downloaded the Cricut app before, so open it and follow all the steps.
How Can I Fix Slow Working of the Cricut Software on Mac?
Sometimes, the reason for this is the slow internet speed. So, ensure to save your work first and then force Reload to fix the error you are having with this app. Follow these steps and fix the issue.
- Start to fix the issue by going to the Cricut Design app.
- Go to the left of your Mac screen.
- Select the View option.
- Look at the drop-down menu and tap Force Reload.
