A few days back, I added a Cricut machine to my craft room, and now I am looking for the right info on how do I connect Cricut to Bluetooth. It is a minimal topic to you, but it is crucial for all crafters. The most important step I should do is to set up my Cricut machine and then connect it to my computer and mobile device. Cricut is an American brand that develops crafting machines that cut various materials. Besides creating DIY projects, the Cricut can connect to PCs and smartphones.
Until now, I have learned that my Cricut machine can easily connect to other devices using a USB cable and Bluetooth. After connecting both devices, I can design numerous customized projects within minutes. Refer to this guide if you are looking forward to getting any Cricut model.
How Do I Connect Cricut to Bluetooth on My Desktop?
Most crafters prefer to connect their craft plotter to a desktop by enabling their desktop Bluetooth. Get to know about the steps that you need to take while wirelessly connecting your Windows or Mac computer to any Cricut machine:
Windows
Take the help of the below steps as it will help you understand how to connect Cricut to a Windows computer using Bluetooth:
- Kickstart the wireless connection process by checking that your machine is on.
- After that, ensure that both of your devices are kept at a distance of 10-15 ft apart from each other.
- Now, go to the Start menu and click the Settings tab (visible as gear icon).
![](https://cricricutdesigncut.files.wordpress.com/2024/04/how-do-i-connect-cricut-to-bluetooth.png?w=491)
- Next, click the Devices option and confirm that the Bluetooth is on.
- If the Bluetooth is off, enable it and press the Add Bluetooth or other device option.
![](https://cricricutdesigncut.files.wordpress.com/2024/04/how-do-i-connect-cricut-to-bluetooth1.png?w=829)
- Following this, tap the Bluetooth button inside the Add a Device window.
- At this point, you must hold on until your Windows computer is looking for nearby devices.
- Afterward, choose your craft plotter from the list, and your wireless connection process will be finished.
- Conclude the process by opening the Cricut New Product Setup page and checking whether the connection has been built successfully.
Also, Mac users are instructed to pay special attention to the coming section of the blog.
Mac
Subsequently, the mandatory set of instructions that you need to take while wirelessly connecting the craft plotter to a Mac computer is as follows:
- First, turn on your Cricut machine and place it within the range of 10-15 ft of your Mac device.
- Second, open the Apple menu > select System Preferences and look for the Bluetooth option.
![](https://cricricutdesigncut.files.wordpress.com/2024/04/how-do-i-connect-cricut-to-bluetooth2.png?w=566)
- Third, enable your Mac Bluetooth by ticking the Turn Bluetooth On button on the left side of the page.
- After enabling Bluetooth, choose your model anime from the list given in the Devices section.
- Through these steps, your machine will connect to your Mac within a few minutes.
On the other hand, if you are a mobile device user and want to learn about the connection process, read the following section.
How Do I Connect Cricut to Bluetooth on My Mobile Devices?
It doesn’t matter whether you own an Android or an iOS device. This part will teach you many things if you are a passionate crafter and want to create new things.
Android
Check out the coming pointers, as they will help you come across the steps needed to be taken for wirelessly connecting the craft plotter to an Android device:
- Initiate the method by checking that your Cricut is on and set within 10-15 ft range from each other.
- Next, move your phone home screen, look for the Settings tab, and open it.
![](https://cricricutdesigncut.files.wordpress.com/2024/04/how-do-i-connect-cricut-to-bluetooth5.jpg?w=253)
- Afterward, click the Bluetooth option and check whether it is on or not.
- If it isn’t on, enable it by moving the toggle to the right-hand side.
- Now, select your Cricut model from the list visible on your screen.
- Lastly, your machine will now connect to your Android device.
On the other hand, get to learn how do I connect Cricut to Bluetooth to iOS devices in the next section.
iOS
Further adding to the blog, let’s discuss connecting iOS devices (iPad, iPhones) to machines by enabling Bluetooth. To do that, you need to take a look at the info mentioned in the coming pointers:
- Start by checking that your Cricut machine is on and placed within 10-15 ft apart.
- Next, open the Settings tab and then hit the Bluetooth option.
![](https://cricricutdesigncut.files.wordpress.com/2024/04/how-do-i-connect-cricut-to-bluetooth4.jpg?w=300)
- Now, check that your iOS device’s Bluetooth is on and wait till your device is scanning the nearby device.
- You have successfully connected the Cricut machine to your iOS devices through these steps.
Once you have summarized the process of connecting the craft plotter to your PCs and mobile devices, you will make several DIY projects. In addition to Bluetooth, you can also connect your Cricut to your PCs or smartphones via USB cable. Before proceeding, you must set up both devices and proceed with the connection process.
Frequently Asked Questions
Question: How to Connect Cricut to PC Using a USB Cable?
Answer: If your Cricut doesn’t support Bluetooth, you can connect with a USB cable. Read the below steps to learn about the wired connection process:
- Check that your Cricut product is on and at the correct distance from your PC.
- Unpack the USB cable, hold its one end, and insert it into the machine’s USB port.
- Take the other end of the cable and put it inside your PC USB port.
- Now, open Design Space on your PC and go to the New Product Setup page.
- Finally, your PC will show that the connection has been made successfully.
Question: Why My Cricut Isn’t Connecting to Device?
Answer: The primary factors due to which your machine is failing to connect to nearby devices are as follows:
- Incompatible devices
- The process you are using is wrong
- Network issues
- You are using the wrong USB cable
- Bluetooth is disabled
Question: How to Setup Cricut Machine on Mobile Device?
Answer: To setup your craft plotter on mobile devices, you need to follow these steps:
- First, plugin your craft plotter and switch it on.
- After doing that, connect your devices using a USB cable or via Bluetooth.
- Next, download & install the Cricut app and sign in with your login details.
- Now, go through the instructions, and the setup will come to an end.
Question: How to Fix My Cricut Not Connecting to Device Issue?
Answer: With the help of these methods to solve your device connection issues:
- Cross-check that you are using the correct USB cable and putting it in the correct port.
- Turn on Bluetooth, and don’t close it till it detects your machine.
- Check that the firewall isn’t blocking the device.
Question: How Can I Connect Cricut to My PC Wirelessly?
Answer: Get to know about the steps for connecting Cricut to a PC wirelessly:
- Check that your craft plotter is on and set on a flat surface.
- After doing that, please turn on your computer’s Bluetooth and let it scan the nearby devices.
- Now, choose your machine from the list, and your connection will be finished.
