IOT Air Compressor
boris-van-galvinBoris van Galvin wrote 10/30/2017 at 00:29 • 1 min read • Like
Some years ago I purchased an old compressor that has been a work horse. A year ago the mechanical pressure switch and contractor's gave out causing the compressor to no longer turn off despite trying to persuade it with a hammer.
I replaced the assembly at a cost of about $120.00
The other day to my dismay the switch failed again, this time it will not turn the compressor on.
Rather than just replace the switching system again I decided to build a new one with some smarts and using an ESP8266, a pressure sensor and a solid state relay I have begun putting together and coding a smart switching system that connected to the local network.
Like
