No Torx driver quick hack
morganmorgan wrote 07/20/2018 at 17:42 • 2 min read • Like
I found myself with a T10 I needed to remove the micro-adjust from a router. I had the hex bit but the driver was too wide to fit in the hole. Using a hacksaw I put a slot in the back of the bit and used a flathead driver. Worked like a charm and the hex bit should be fine otherwise.
Like
