High (110) voltage DC motor driver with PWM / direction inputs for cheap.
James Newton wrote 12/22/2018 at 01:01 0 points
Hey, anyone have advice on driving high voltage brushed DC motors? E.g. treadmill motors or the lovely old ones that last forever if you change the brushes out? They are available for dirt (I got 3 for $15 each! Working!) and yes, I know the new BLDC motors poop rainbows, but doing things on the cheap appeals to some of us.
I don't need super smooth, perfect, clean drive... just power and maybe 10 levels of it. I'm thinking industrial lamp dimmers? Or just feed from the 110 volt line directly but only give it X positive cycles out of 10? (or X negative cycles to go in reverse). If I switch on and off at the zero crossing, it should limit the noise and back EMF and whatever.
Can't seem to find any DC motor controllers that can 1. manage 110 volts and 2. reverse and 3. accept digital control signals (e.g. no knobs... PWM and direction input)
