fixing rather than building: rules for buying old test equipment
worsthorseworsthorse wrote 10/23/2019 at 18:41 • 3 min read • Like
For the last year or so, I've been acquiring older (80s and 90s, mostly) test gear.  Lots of it comes from hamfests, most of it is is in poor physical condition from long storage, and little of it works when I plug it in. This means it is cheap.  It also means that, if one can get it working, the price/performance is often quite amazing.
An example: I just picked up two Fluke 8800A DMMs.  5.5 digits, 4 wire resistance measurements, mV to KV range, etc.  The new version of this meter sells for almost 900USD.  I bought these two for fifteen bucks.  Granted, they weren't in great shape:
But even if I combine two meters into one (and baseed on an hour's work of bench time, it looks like I can) I get a working precision DMM for a twentieth of the cost of a new model. That's a pretty good deal.
Other than the siglent SA on my bench, almost everything I use - signal generators, DMMs, oscilloscopes, power supplies - looked like these two meters when I bought them.
Here's some simple rules to follow:
Though these rules are my primary guide to buying, sometimes I take the lottery ticket approach: this is really cheap and if I can get it to work it will be a huge win!   Sometimes it doesn't work out... I bought two HP function generators that are essentially bricks; although I know how to fix them, I will never find the custom ICs that need to be replaced.  The same day, I bought a B+K curve tracer that was up an running after an hour on the repair bench.
Even if you can afford to buy the latest and greatest test equipment, mucking with older gear is a great way to learn how TE works. Gear from the 80s and 90s typically comes with extensive documentation including the theory of operation, use cases, schematics, and calibration instructions.  You won't get much of that when you buy a Siglent scope!
Last thing. You can find a lot of good stuff on test equipment over on the eevblog TE forum. I post tear downs and repairs (these two Fluke meters will be there), as do a lot of other folks.
Like
