I made a flying saucer from recycled components.
![](https://cdn.hackaday.io/images/1932401586097671487.jpg)
One part was a gear box from an old VCR (Video Cassette Recorder). Another was a shower cap. I also used 1 mm metal wire.
![](https://cdn.hackaday.io/images/2103861586097710987.jpg)
You can see the sculpture spinning in those YouTube videos:
Step 1: Attach the Shower Cap to Gearbox
I used pliers and thin metal wire to make a few loops in and out of the holes of the shower cap and the wheel.
![](https://cdn.hackaday.io/images/28051586097588764.jpg)
Note that the small purple wheel has a bolt that is used to tighten the wheel to the gear rod.
![](https://cdn.hackaday.io/images/538101586097597805.jpg)
Step 2: Put the Shower Cap Lid On
I attached the lid easily:
![](https://cdn.hackaday.io/images/2869891586097526977.jpg)
Step 3: Testing
I connected the gear to my bench top power supply.
This is the fastest speed that spinning sculpture reached:
The voltage from my power supply must have been about 6 V.
