Top 10 Drone Frames in India
akanzler007akanzler007 wrote 05/29/2020 at 06:16 • 8 min read • Like
With the Demand of Drones increasing day by day, the protection  of drones has also become important.
Drone frame is one of  the important component of a Drone. The structure that holds all the components together. One of the most important part of Drone is its frame because it supports motors and other electronics and prevents them from vibrations. You have to be very precise while making it. They need to be designed to be strong but also lightweight.
You probably know that there are different types and configurations of drone frames. This guide will take you through some of the best drone frames that will keep your drones safe and long-lived.
1. Q450 Quadcopter Frame
The Q450 Quadcopter Frame is very popular and mostly used Multirotor Frame by the hobbyists!!! This is 3rd version of Q450 Quadcopter Frame comes with stronger material over v1 and v2, so no more arm breakage at the motor mounts on a hard landing. The arms of the frame are colored as 2 red and 2 white which can guide you to fly in the right direction.
They are strong, light, and have a sensible configuration including a PCB(Printed Circuit Board) with which you can directly solder your ESC‘s to the Quadcopter. Thus, making the Quadcopter build fast and easy. Much lighter weight, higher strength Aerodynamic structure of this Q450 frame featuring PA66 arms with glass fiber integrated frame make it the first choice of our customer.
Price – 850Rs
For getting the Q450 Quadcopter Frame Click Here
2.    Q100 Brushed Quad-copter Frame
The Q100 is a mini-size smallest frame among the quadcopter frame class. The compact design with ABS plastic body has made them popular in FPV racing. This is ready-2-fly quadcopter frame requires only basic installation. You can enjoy the versatility of the Q100 racing drone by practicing your flying, racing, or aerial acrobatic drone skills either indoors or outside in tough environmental conditions.
The frame is designed in such a way that all the necessary component with a camera can be easily installedIt has the pre-reserved mounting hole for mini FPV camera. The frame has the wheelbase of 100mm and weighs around 12gm. The Q100 Mini Quadcopter Frame is lightweight, has excellent agility and less destructive inertia in a crash.
Price – 299Rs
For Getting Q100 Quadcopter Frame Click Here
3.    F550 Hexa-Copter Frame
This is Hexacopter Frame which employs 6 arms to get into the air. This frame is for a bigger drone where an extra amount of batteries, motors and accessories can fit in.  This F550 Hexa-Copter Frame is made from Glass Fiber which makes it tough and durable. They have the arms of ultra-durable Polyamide-Nylon which are the stronger molded arms having a very good thickness so no more arm breakage at the motor mounts on a hard landing.
 The arms have support ridges on them, which improves stability and provides faster forward flight. The frame has the wheelbase of 550mm and weighs around 620gm. It features mounting tabs at the front and rear end on the bottom plate of the mainframe for mounting cameras and other accessories.
Price – 1990Rs
For Getting F550 Hexa-copter Frame Click Here
4.    S500 Multi Rotor Air PCB Frame
The S500 Multi-Rotor Air PCB Frame serves as the upgradation of F450 Quadcopter Frame. It keeps everything that has made the F450 Quadcopter frame successful. The main great advantage of this frame is the arms have a slight upsweep, this gives the Quadcopter a dihedral effect which helps to make it very stable, especially when descending from altitude. The arms have a carbon fibre rod through the center for making the strongest arms we have seen to date in this style of frame. The Blue and black arms make orientation much easier and there is no need for different color props.
The frame has the wheelbase of 500mm and weighs around 400gm. It features mounting tabs at the front and rear end on the bottom plate of the mainframe for mounting cameras and other accessories. The landing gear has the ground clearance of 200mm and allows the mounting of the camera and other accessories at the bottom of the mainframe. The landing gear has plenty of height making it suitable for gimbals. The Plastic Landing Gear can withstand sudden crashes during flying of FPV Quadcopters.
Price – 1876Rs
For Getting S500 Multi Rotor Air PCB Frame Click Here
5.    Q250 Quadcopter Frame Kit
The Q250 is a mini-size quadcopter frame. This frame is built specifically to tackle the problems in FPV Racing and video recording with quadcopters. This frame is known for its toughness and durability. This Q250 Quadcopter Frame is made from Carbon Fiber which makes it tough and durable. The carbon fiber arms of thickness 3mm which ensure no more arm breakage at the motor mounts on a hard landing. The arms have dampers at the end, which protects motors during the crash.
The frame is lightweight and possesses thick arms, so as to give them good mechanical strength. The mini-size design of this quadcopter frame makes it aerodynamically efficient which will require lower throttle to hover. Its longer top and bottom plate allow easy mounting of HD cameras and batteries so more spacious room for all kinds of electronics!!
Price – 1190Rs
For Getting Q250 Quadcopter Frame Kit Click Here
6.    F330 Glass Fiber Mini Quadcopter Frame
This F330 Quadcopter Frame is made from Glass Fiber which makes it tough and durable. They have the arms of ultra-durable Polyamide Nylon which are the stronger molded arms having a very good thickness so no more arm breakage at the motor mounts on a hard landing. The arms have support ridges on them, which improves stability and provides faster forward flight.
The F330 Glass Fiber Mini Quadcopter Frame is strong, light, and has a sensible configuration including a PCB(Printed Circuit Board) with which you can directly solder your ESC‘s to the Quadcopter. So, making the Quadcopter build fast and easy. The frame has the wheelbase of 330mm and weighs around 170gm. It features mounting tabs at the front and rear end on the bottom plate of the main frame for mounting cameras and other accessories.
Price – 750Rs.
For Getting F330 Quadcopter Frame Click Here
7.    TBS 500 Frame KIT
This TBS 500 Carbon fiber frame is made from 3K Carbon Fiber which makes it tough and durable. They have the arms of ultra-durable Polyamide-Nylon which are the stronger molded arms having a very good thickness so no more arm breakage at the motor mounts on a hard landing. The arms have support ridges on them, which improves stability and provides faster forward flight.
The frame has a wheelbase of 500mm and weighs around 400gm. It features a mounting tab at the rear end on the bottom plate of the mainframe for mounting Batteries. The added lift capacity makes this frame ideal for carrying larger payloads such as camera systems and Gimbal.
It requires one size of bolt for the overall build and thus a unique one-size hex wrench which makes hardware mounting very convenient. This feature of TBS Quadcopter Frames makes them so easy to assemble and disassemble.
Price – 1990Rs
For Getting TBS 500 Frame Kit Click Here
8.    QX95 Brushed Racing Quadcopter Frame
This is the Unmanned Tech produced QX95 brushed FPV quadcopter frame. It is a lightweight frame which has a wheelbase of 95mm and it is constructed out of carbon fibre for extra robustness. The frame is designed in such a way that all the necessary component with a camera can be easily installed
Price – 499Rs
For Getting Qx95 FPV Quadcopter Frame Click Here
9.    MARTIAN-III REPTILE Quadcopter Frame
This MARTIAN-III REPTILE 260mm Quadcopter Frame is made from Carbon Fiber which makes it tough and durable. They have carbon fiber arms of thickness 4mm which ensure no more arm breakage at the motor mounts on a hard landing. The arms equip dampers at the end, which protects motors during the crash.
The frame enables quick swapping of arms in race pit settings. It is designed to fit standard flight controllers/PDB, FPV cameras and also FPV transmitters and antenna.
Price – 1690Rs
For Getting Martian – III Reptile Quadcopter Frame Click Here
10.    Mini 290 6-Axis Hexacopter Frame
This Mini 290 6-Axis FPV Racer Pure Carbon Fiber Hexacopter Frame is ideal for drone racing because of it’s capability of withstanding punishing requirements of a racing drone! They have pure carbon fiber arms of thickness 3mm which eliminates arm breakage at the motor mounts on a hard landing.
The frame has the wheelbase of 290mm and weighs around 180gm. The Mini 290 6-Axis FPV Racer Pure Carbon Fiber Hexacopter Frame is specially designed for racing drones and has lots of space for mounting all the required componentsThis frame is ideal for mounting Cameras and other accessories.
Price – 1950Rs
For Getting Mini 290 Hexacopter Frame Click Here
To Explore More Drone Frames Click Here
Like
