Hey Guys, another solution to soldering of smd chips like TQF 32. ATMEGA328P-AU is a TQF base package IC which is commonly found on Arduino nano. If you want to use this IC separately it would be not easy so to ease it there is a solution of designing a SMD, TQF32 TO dip converter which can be used to use the ATMEGA328P-AU IC externally. It is not something hard but only a simple designing technique to design for TQF32 to TQF64 base converter. Advantage of these type of converters it that, you don’t need to design different PCB for different pin IC rather you could use the same one ranging from 32 to 64 pins. Pins for the converter are provided on each side of the PCB so that it can be an easy thing to connect it through jumper wires. This technique can be used for any IC which is in SMD package. Designing an PCB is not great task but choosing the right manufacturer is must. For all these types of work I choose NextPCB which provide great quality PCB in short time. Ordering PCB online in various sites are a step towards developing our own circuit. NextPCB provides very easy😎 and fast delivery🚚 of PCB in different masks and paste with professional look. Also, they send you the picture of your PCB before shipping it to you, Now that very exciting…😃😃👍. #arduino #arduinouno #arduinoproject #arduinomega #arduinonano #arduino duo
