THEORY OF M.I.N.D. :
"A heat sensor can detect heat, but it does not mean it can conceive or conceptualize heat".
In this article, we will argue that the heat sensor can actually conceive the presence of heat. It can be done through the Theory of the Second Option, Theory of Queue, Codexation, Generated Emergence, and Systems of Intuitive Networks. Once we prove this, one of the signatures of Life called by the mainstream as self-consciousness will be invalidated, discontinued, and must be rewritten. A new word, called Aneural Inlearness, replaces the debunked term.
The ability to conceive or conceptualize is sometimes called having a “theory of mind.” However, surprisingly, this theory depends too much on the presence of the brain, specifically on its fundamentals units called neurons. Neurons are specialized cells responsible for receiving and transmitting sensory inputs and outputs from and to the nervous system and the brain. The brain is believed to be the place where information is stored and processed, while the nervous system is the super-highways that relay instructions to every muscle of the body. However, we know now that the brain is not always the seat of inlearned information due to the facts uncovered in the various experimental models on Aneural Systems of Intuitive Networks (a brain without the brain) or the Brainless Memory Systems.
One of the Intuitive Network Systems is the basic aneural memory system shown below:
In this illustration, the system stores and processes information. It receives a signal from an external source. In this example, the hand is the source or the trigger mechanism that turns On and OFF the switch. The switch stores two kinds of instructions, 0 and 1. Zero means off while One means On. The wires serve as the highways where information is transported and relayed from one point to another. The bulb is actuated when there is a presence or absence of signals. When a signal is present, the bulb is ON. When a signal is absent, the bulb is OFF. This type of system does not need a brain. This "brainless" memory system is called Linear Aneural Wise System or Aneural Memory Systems in short.
Thus, it is not always true that the brain is the only place that stores and processes information. In fact, there are so many ways where information is stored and processed without the help of the brain (see Aneural Memory Systems)
Now, let us examine deeper the pictorial diagram and tell me which part of the system can be the brain be added or placed. Is the brain really necessary in an intelligent system? If not, then the brain does not really store information as many experts disavow. In fact, thoughts, reasons, emotions, ideas do not need to emanate from the brain. To prove these assertions, let us go back to our first argument: heat sensors can actually conceive the presence of heat.
Brainless Memory System:
Fungi are examples of life-forms without a brain.
Another example of a Brainless Memory System or Intuitive Memory System is the machine in the video. It is not programmed by any means. The behavior of the machine to go in circles is due to Inscription by Design with its intuitive objects and embedded instructions.
Excerpt: Originmelogy
"Every creature is a living instruction that runs the algorithm of life." ~ Joey Lawsin
Biotronics™ AOUIE™ Exyzforms™ Zoikrons™ ELFS™ Autognorics™ I.M.™
are original trademarks and logos
solely distributed by
Line A WorkStation Information Network
