Two Button Relay Switch
web-circuitsWeb Circuits wrote 12/29/2020 at 09:15 • 1 min read • Like
This article is based on information that was clearly explained in this link:
https://www.instructables.com/Two-Button-Relay-Switch/
I modified the circuit to replace the R2 resistor with a diode to improve the performance and reliability of the circuit in the link above.
Step 1: Design the Circuit
I used the PSpice student edition software version 9.1:
The light bulb can be replaced with a moderate current LED lighting source.
Step 2: Simulations
Transient (relay input voltage):
Transient (load voltage):
Conclusion
My circuit was not tested. However, I believe it can work.
Like
