Simple use of a laser cutter. The monitor won't be the fastest or the cheapest, BUT it will be a 60hz monitor that can be customized yourself and rebuilt later.
17" monitor made with a laptop display, controller, and laser cut parts.
monitor.svgThe cutting templates for the monitor. Use of a drill to ensure that the holes align and go all the way through is a good idea.svg+xml - 47.39 kB - 03/06/2016 at 10:45 |
./next_feed_start
Added some photos and build instructions.
./next_feed_end
./feed_start
Setting up this page for a build log, post-production. Will be making another shortly with more detailed assembly instructions.
./feed_end
Cut sheet material using a laser by way of the template.
Stack cut out pieces
Drill out holes
