PROBLEM:
Not everyone can own a pcb mill or a cnc machine. Sometimes using a dremel to drill holes becomes tedious. If you are like me an etch your own pcb prototypes, drilling the holes is sometimes the reason you buy pizza a case of energy drinks and invite some friends over and hook them into helping you finish the drilling.
SOLUTION:
The "PressDrill 9000" provides a Monitor , Camera and an actuated Plunge feature by a foot pedal that will improve your at home pcb fabrication.
Daniel Frausto
