The Inkscape file is included in the Download, So you can change this to any Logo You feel fits.... Dont Forget to give Us a Hackaday Thumbs up so we can cover our costs to keep more Case Designs Coming.
See Main page on how to cut this case for yourself. There will be a place near you that gives free seat time on a Laser cutter, get Hacktive.
Material: >3mm Ply or Acrylic [6x30cm] >Four of 3mm bolts
Element14 Logo Is on there because they were kind enough to send out a free screen. The Inkscape file is included in the Download, So you can change this to any Logo You feel fits.... Dont Forget to give Us a Hackaday Thumbs up so we can cover our costs to keep more Case Designs Coming.
Material: >3mm Ply or Acrylic [60x30cm] >Four of 3mm bolts
Inkscape starter kit page is here: I found it quite easy to use the two or three colours needed and setting tthe line width to the required size. Cheers...
I will look into what Ponoko is [:/] The laser cutter I have seat time on uses line widths to determine cuts vs etch. If Colour is another common method, sure they will be released in color too soon.
http://www.ponoko.com/starter-kits/inkscape
