Now talking to io.adafruit.com
A project log for Beehive Monitoring, Now With WiFi
Using a WeMos ESP8266 D1 Mini and DHT22 Shield to monitor beehive temperature and humidity
don-r-crenshawDon R-Crenshaw • 11/11/2016 at 04:54•0 Comments
I decided to add MQTT messaging to io.adafruit.com to create a couple publicly available dashboards.
When I changed the code to add the Adafruit dashboards, I updated some libraries which led to no end of fun. Long story short, one sensor was sending data to pin 2 on the Huzzah. The updated libraries broke this. When I tested, I assumed my terrible build quality had created the problem. Much testing later, I solved the problem by moving the sensor to pin 12.
There are now two public dashboards:
a week's worth of graphical data
and
The current (within ~30 minutes) readings.
The updated code has been pushed to my the master branch of my github repository.
