The (semi-aborted) front panel
A project log for Quick & Dirty Frequency Generator
Because I need it, I can and I'm cheap. So maybe I'll do.
yann-guidon-ygdesYann Guidon / YGDES 05/01/2016 at 18:130 Comments
I recently started hacking a control interface for the system but is soon got out of hand. For example, I thought that I could get the whole thing, (buttons, ALU, display and dividers) on the same pretty narrow board.
It turns out, I can't really. I added a "bypass" system with '165 and '595 shift registers to read the buttons, and override their value, to provide external control (and debouncing, or even smooth fading) and there is not even a TIL311 or #DYPLED in sight.
So I moved the frequency/signal processing to another board behind it.
Then, other projects happened.
Anyway, I'm now having a pretty cool clock source and some PLLs so the story is not over. Yet.
