I had the itch to be able to get digital copies of printables from my gameboy games. Fortunately someone had done the hard work of doing the printer communications via an arduino <a href="https://importhack.wordpress.com/2014/04/17/gbcamera-imagesaver/" target="_blank">https://importhack.wordpress.com/2014/04/17/gbcamera-imagesaver/</a>.
I was able to duplicate his results on my uno testbed and then pack it into a pill bottle inline through an arduino nano. This gives a neat cable with the GB link on one end and USB on the other!
However, the python code was written specifically to handle images from the GB camera. Those images are always the same size, whereas the titles I have like Super Mario Bros Deluxe and Pokemon G/S/C print images of varying lengths.
<a href="https://github.com/metheos/GBcamera-ImageSaver" target="_blank">https://github.com/metheos/GBcamera-ImageSaver</a>
I adjusted it so that it will handle prints of any length. I also added realtime ascii previews!
i would like to print the certificate for completing the pokedex in crystal.
but i am new to arduinos and python and dont exactly know how to use your stuff.
i set the hardware up as you described, and when i start to print something the Error 2 appears on my GBA then after a few seconds it is sending data, then he says printing for half a second and back to errror 2....repeating that whole 2 times before stopping....is this able to work so far?^^
The Arduino Monitor only shows at a Baudrate of 115200 :
GameBoy ImageSaver v0.1: Setup done. ?
and how to make arduino work with phython i sadly have no idea...
I changed the folder in the conf.py script as you mentioned
Hello,
please help me^^
