C64 datasette emulator
Load TAP images from a SD card to an unmodified C64
This project is a small cartridge-like module which emulates a Datasette tape player. It is powered from the C64, and includes a small LCD display for the user interface. The microcontroller uses 3V3 supply voltage, which simplifies the communication with a microSD card; the communication with the 5V C64 is done via a simple voltage level shifter.
  • 1 × 10k SMD potentiometer
  • 9 × 1k 0805 resistor
  • 2 × 3k3 0805 resistor
  • 1 × 10k 0805 resistor
  • 8 × 100n 0805 capacitor
View all 12 components
