I put together a small kit that contains a custom PCB, 10mm LED, resistor, button, battery holder, CR2032 battery, and finally the instructions. The point of the kit is to teach about soldering and 3D printing. The soldering is very simple and anyone should be able to do as their first soldering job. The body for the flashlight is then 3D printed and everything snaps together.
1×
10mm LED - White
https://www.aliexpress.com/item/10mm-White-LED-Round-Light-Emitting-Diode-Transparent-Ultra-Bright-Lamp-Bead-Plug-in-DIY-Kit/32681799244.html
