First ideas
A project log for Waffle: a pocket-sized digital radio system
µController, CC1101 module and LCD forming a small communication device. Other probable uses in the near future.
mdasilvaM.daSilva 04/22/2016 at 12:440 Comments
So, I'm starting off by doing the whole hardware part, which is very simple. I can always work on the software further down the line, as long as the hardware is already correctly defined.
I intend to use my system in two different ways for now:
Both should be able to be implemented with the same hardware:
So first thing that has to be done is the Main Board, which will include the 3 first points. The power amplifier will be designed later on.
