The three 'R's...
A project log for Ferrite Core Memory Module
A sub-project of the ED-64 Computer to document the development of a 64-byte ferrite core memory module
Andrew StarrAndrew Starr 04/10/2017 at 08:0210 Comments
Reading, writing, and repairing.
The last few weeks have seen significant progress, to the point where I can read and write data to the the cores, with the following limitations:
1. I screwed up the design of the Inhibit module, so I can only write 1 zero in a byte. I have corrected the module design, and I expect the corrected boards to arrive any day now.
2. The system currently takes about 30 mins to warm up. If I run a continuous memory test on the cores (writing 0xFFs/0xEFs), a serial printout of erroneous memory locations gradually gets shorter and shorter, until they're all ok. I'm not sure what the issue is, but I suspect the bias diodes (1N4148s) in the sense amplifiers. The sense amplifiers are a bit kludgey, so I'm reluctant to disturb them too much until I have corrected boards for them - the next job, after the inhibit module. Then I can investigate properly, without worrying about breaking shitty soldering joints or shorting kludge wires.
Anyway, here's a few pics of the current setup:
In the picture above you can see my Quality Assurance Technician (QAT) hard at work.
The rear of the memory system, currently controlled with a Arduino Mega 2560, and the power supply. Note the cat-5e cables - this is how the various computer subsystems will be interconnected.
[deleted]
Yann Guidon / YGDES wrote 04/13/2017 at 12:30 point
The quality assurance technician's work is not to be happy...
Andrew Starr wrote 04/13/2017 at 22:39 point
Of course not, she isn't being fed at that particular moment :)
Yann Guidon / YGDES wrote 04/13/2017 at 23:52 point
obviously not :-)
Blecky wrote 04/19/2017 at 11:02 point
"The F is this shit? I'm writing you up!"
Yann Guidon / YGDES wrote 04/10/2017 at 08:09 point
Where do you get these fine boards manufactured ?
Andrew Starr wrote 04/10/2017 at 08:12 point
pcbway.com. They're the one of the cheapest board houses out there, and the quality is good.
Yann Guidon / YGDES wrote 04/10/2017 at 08:23 point
your base boards are quite large, how much did they cost ?
Andrew Starr wrote 04/10/2017 at 08:28 point
The base boards are 275 x 177mm, 4 layers. Currently US$216 for 5, including freight to La Belle France :)
Yann Guidon / YGDES wrote 04/10/2017 at 08:05 point
Meow...
Andrew Starr wrote 04/10/2017 at 08:08 point
Damn thing is a camera hog
