Demonstration quantum yield analysis
05/08/2016 at 08:36 • 0 commentsI finally figured out how to calculate the quantum yield of my samples, so I used a known reference from the Oregon medical laser center (fluorescein in ethanol) and compared it to my new buffer solution of KBr (potassium bromide.)
Then I compared a sample of fluorescein I had done on May 3rd (fluorescein in ethanol) to the laser center's sample to get a more accurate quantum yield value.
Oscilloscope data on the JDEPC-ov04 camera
05/05/2016 at 21:41 • 0 commentsI finally got to take some good readings from my oscilloscope program on the JDEPC-ov04 camera in my spectrometer, it doesn't work when the camera is running, but I can get good data on dB levels when it is at rest and on stand-by for data capture.
I did a low pass and a high pass scan:
This is the low pass scan in dB levels at rest.
This is the high pass scan in dB levels at stand-by for data capture.This is very useful information because now I have a better idea about the spectrometer's internal noise as it relates to data aquisition. -
Added a new High power LED to the mix...
05/03/2016 at 21:47 • 0 comments -
Rhodamine B analysis using spekwin32's hardware control prototype
05/02/2016 at 20:09 • 0 comments -
Demonstrating the capabilities of my spectrometer
05/01/2016 at 09:28 • 0 comments- Further demonstrating the capabilities of my homemade spectrometer is a calibration curve done on 2 stroke motor oil:
Graph showing cfl plot blue band at 436nm and green band at 547nm
correction curve showing calibration quality fit of 3, target is always a fit of "0" but alas, soooo...far away!
After upgrading the DVD grating this weekend I naturally had to run a series of tests to recheck alignment and resolution, so this is a great demonstration of what a homemade spectrometer can do!
Fluorescein study 6 sample concentrations :
Plab spectrometer v2.5 (build 3.0.1)
05/01/2016 at 08:03 • 1 commentI updated the DVD grating this weekend and realigned it, so it is as straight as possible in relation to the slit and remains at a 45 degree angle. With the way it was, I was getting some mis-alignment from time to time, so I had to take care of that.
