I present Oshwi, the IoT badge.<br><br>The form or figure, is based on the mascot of the maker event, "OSHWDem", which takes place every year in the month of November in La Coruña Spain, and in Hardware in the Huzzah product of Adafruit that is an open project, how much 5 addressable Neopixeles and an ESP-12 microcontroller that incorporates WiFI, is designed using open software like, Kicad, Inkscape, and much, much love from Mazatlan, Mexico for the whole world !!!<br><br>I have published all the files on Github, I hope you like it.<br><a target="_blank" rel="noopener noreferrer" href="https://github.com/hulkco/oshwi_2017">https://github.com/hulkco/oshwi_2017</a>
I noticed that your PCB edge is discretized as a large amount of small segments... would you mind to share the original SVG file (based on BSplines I suppose) you used to create the PCB outline? I would like to convert it to a more compact PCB edge, converting BSplines to Arcs and Lines...
Hi,
very nice piece of artwork!
I'm playing a bit with it in FreeCAD and I would like to be able to import the PCB with my StepUp tools (https://github.com/easyw/kicadStepUpMod)
(some reference here https://hackaday.io/project/27354-kicad-stepup-new-hack-the-sketcher )
Thanks
Maurice
