1.Use the laser cutting to make a wood board to fix every led bar in sequence.
Here is the details of the laser cutting effect on a 5mm wood board.
2.configure every I/O of the wio link or wio node.There are 30 I/O for 30 led bars.
Here I used wio node instead of wio link.
3.Connect the led bar to wio node grove interface with grove wire.
4.Choose the number of the led you want to control, then send the relevant parameter to the API of the I/O.
5.Then you will see the amazing effect of the tele-controlling experience.If you are thousands of miles away, you can see the effect through Live broadcast!
The broadcast of my Internet Of Led Wall is here.
You may also need Fusion PCB service to make further extention.
carbono.silício
Simon Betts
Debajyoti sarkar
you have created a tiny LED wall using Wio nodes and that each node can be controlled through the internet. This setup suggests that you have used Wio nodes, which are a series of development boards designed for IoT projects, to create an LED display that can be accessed and controlled remotely via the internet.
