A reed relay toggle flip that directs the toggle signal to one of two outputs
A project log for RelayRepRap
This project is about exploring whether it is possible to make a RepRap control system that can be made by a RepRap.
willstevenswill.stevens 09/16/2016 at 23:140 Comments
In order to make a modulo 12 counter like this one, but using easy to make single throw relays, a circuit like the one shown in the video below is needed.
In the video the circuit uses 4 DPST relays, I believe that it could be made with 6 SPST relays instead. If so then this means that a modulo 12 counter will require 30 SPST relays.
